envision
arman
envision
Post by arman »
Your Portal Version: 1.0.4
PHP Version: 3.0.6
no problem yet
no problem yet
Hi, has anyone using the envision style, installed the board3 portal? I would like to know if you just install it as per subsliver2 edits (as its subsliver2 based style and i have used those edits for previous mods). I feel confident that most mods should work for envision using subsilver2 as my previous mods have.. however this board3 portal mod will be the biggest mod so far and so I don't want to stuff it up. any help is appreciated
Return to “Styles Support”
