[SOLVED]install_main.html does not exist or is empty
Tandem01
Post by Tandem01 »
Boardlink: http://www.familia-21.hostoi.com/foro/install/index.php
Follow all instructions and try to connect to my site to run the installer.
I try to find manually the files install_main.html but I fail.
The complete error message is:
Error general
template->_tpl_load_file(): File ../adm/style/install_main.html does not exist or is empty
Can someone plesar tell where I can find the missing file?
Thanks, Tandem01
Too many hours in front of the screen... After a good film with good company, all seems to be in place, so I copied the forgoten files i the correct place...
Thanks,
Tandem01
Once we accept our limits, we go beyond them - Albert Einstein.
