I installed the board3 portal on my test forum fine and works a treat here : http://www.jak01.com/Testforumz/phpBB3/portal.php but i installed it up on my main and have done the file edits and it comes up with....
General Error
Table 'jak01-forum.phpbb_3portal_config' doesn't exist
Can anyone help please?
THanks
Jak01
[HELP!]General Erorr!
- phpBB.de User: PeterS
- phpBB.com User: PeterS
Re: [HELP!]General Erorr!
please check your changes in includes/constants.php
and/or check your Database if the table exists.
greetz Peter
Code:Select All
// Additional tables
Code:Select All
define('PORTAL_CONFIG_TABLE', $table_prefix . 'portal_config');
greetz Peter
Hello,Jak01
you use different Versions and have not replaced all Files, some Files are of the phpbb3 Portal and others of the older Version Board3 Portal.
Use the new version of the portal (0.2.1), no support for the phpbb3 portal , Sorry![Zwinkern ;-)](./images/smilies/icon_e_wink.gif)
Walter
Walter
ok, thanks i just went to the install link instead and it works fine now (i am now using board3 portal , as phpbb3portal gave me white pages...)
If you mean your testforum: http://www.jak01.com/Testforumz/phpBB3/portal.phpJak01 wrote:(i am now using board3 portal , as phpbb3portal gave me white pages...)
You still haven't replaced all files!
no , i mean the one running on my main forum witchis http://www.jak01.com/phpBB3 ![Lächeln :)](./images/smilies/icon_e_smile.gif)
Oh - such a beauty! ![Überglücklich :D](./images/smilies/icon_e_biggrin.gif)
