Your Portal Version: 1.0.3
N/A
N/A
Item 39 to 72 in the file copy instructions.
Path's listed as "root/styles/prosilver/template/portal/" but should be "root/styles/prosilver/template/portal/block/"
Section for "Open: adm/index.php" doesn't have any code to replace the listed
v1.0.3 to 1.0.4 Update.XML errors
Re: v1.0.3 to 1.0.4 Update.XML errors
Thank you for the report.
The adm/index.php edit is correc though. You are supposed to delete that code as mentioned in the install file.
Thanks Marc,
Just noticed that.
Suggest you put in comment replacement code to make it clearer what's going on.
i.e. /* superseded code removed Board3 Portal v1.0.4 */
Just noticed that.
