Your Portal Version: 1.0.3
Boardlink: http://www.aoc-lempire.fr/
No Problem, just a question about the update
Hi all,
I wish to update my portal from 3 to 4, but as I have modded several files of the installation (mainly block files) I'd like to know if it's necessary to re-upload all the files from the zip archive, or could I just make changes to files specified installation instructions file ("Files to edit" section)?
Thanks for your help.
Update from 1.0.3 to 1.0.4 / Question
