Error after installing
Luvodicus
Post by Luvodicus »
Boardlink: http://www.mezrscape.com/forum
Uploaded the portal files
Uninstall, reinstall I cannot read the xml files as allthewordsareallscrunchedtogetherlikethiswithnolinebreaksandnoformatting
SQL ERROR [ mysql4 ]
Table 'mez0930507412830.phpbb_portal_config' doesn't exist [1146]
SQL
SELECT config_name, config_value FROM phpbb_portal_config
BACKTRACE
FILE: includes/db/mysql.php
LINE: 174
CALL: dbal->sql_error()
FILE: portal/includes/functions.php
LINE: 32
CALL: dbal_mysql->sql_query()
FILE: includes/functions.php
LINE: 3738
CALL: obtain_portal_config()
FILE: index.php
LINE: 128
CALL: page_header()
Re: Error after installing
1. With what did you open in the install.xml? You need to open it with your internet browser. Your error message tells me you haven't run the installer.
