I have just installed PortalView 100RC2 via AutoMod. The installation was reported as sucessful with no errors.
However, when i now go into the website, I get the following error:
General Error
template->_tpl_load_file(): File ./styles/prosilver/template/portal/portal_header.html does not exist or is empty
Any ideas anyone?
Installation error
Moderator: Dyo
- phpBB.de User: Christian_N
- phpBB.com User: Christian_N
Re: Installation error
Google-English:
This MOD can also manually install well. Installing MODs with EasyMOD / AutoMod is not so good anyway.
Sorry an error in install.xml, please uploaded to your webspace:
Copy: root/styles/prosilver/template/portal/portal_header.html
To: styles/prosilver/template/portal/portal_header.html
Copy: root/styles/prosilver/template/portal/portal_footer.html
To: styles/prosilver/template/portal/portal_footer.html
If subsilver2 installed, please uploaded to your webspace:
Copy: root/styles/subsilver2/template/portal/portal_header.html
To: styles/subsilver2/template/portal/portal_header.html
Copy: root/styles/subsilver2/template/portal/portal_footer.html
To: styles/subsilver2/template/portal/portal_footer.html
