portal center blocks not displaying correctly in Firefox
oldwillyswagons
Post by oldwillyswagons »
Boardlink: http://www.oldwillyswagons.com
I recently installed Portal on my phpbb3 forum and everything seems to be working great with one exception...
The center blocks are not displaying correctly in the current release of Firefox. The blocks are not adjusting in width without the header and content returning to a second line, which scrambles the content a bit. For example, the "last post" text is under the header title, and not over the last post column of content.
Seems to work fine in Safari, but haven't looked at it in IE...
Thoughts?
Thanks,
Pete
Re: portal center blocks not displaying correctly in Firefox
You installed B3P v 1.0.2 or previous. Please update to our last package 1.0.4 ;)
oldwillyswagons
Mike wrote:You installed B3P v 1.0.2 or previous. Please update to our last package 1.0.4 ;)
Thanks Mike-
The latest version on http://www.phpbb.com is 1.0.2. I found the 1.0.4 version here and will give it a shot.
Pete
oldwillyswagons
Another question, can I update from 1.0.2 directly to 1.0.4, or do I have to update to 1.0.3 first?
Thanks for the help.
Pete
Sadly there are no instructions to update directly to 1.0.4 so you need to update to 1.0.3 first...
oldwillyswagons
Ok, I have finished installing the updates and am now on version 1.0.4...
And Firefox is still not displaying the center block correctly correctly... The "last post" text in the header is returned onto another line making the header background fat.
It is better than it was with version 1.0.2, because the last post date/time info was also returned under the post title.
Thanks again for the help-
Pete
go to ACP->portal->news and set "Display the number of replies and views:" to NO
oldwillyswagons
Mike wrote:go to ACP->portal->news and set "Display the number of replies and views:" to NO
Mike-
Made the change in the ACP, but it didn't make a difference in the display... Still the "last post" text is returned onto a new line...
Also, just noticed that after updating to 1.0.4, that the little image icons are all missing from the blocks. What has caused this?
Thanks,
Pete
You have to update your style too... upload all fioles from board3_Portal_104\root\styles\prosilver into your stylefolder, makle the edits as described in installxml for prosilver, and purge your caches.
oldwillyswagons
Mike wrote:You have to update your style too... upload all fioles from board3_Portal_104\root\styles\prosilver into your stylefolder, makle the edits as described in installxml for prosilver, and purge your caches.
Ok, getting closer... Thanks for all your Help Mike, and patience dealing with a complete noob...
The style stuff seems to be updated and the menu icons are now working again.
However, the headers in the Forum List are still showing incorrectly, just like the screen shot I posted earlier. The Latest News and Announcements blocks look right.
Not sure what I'm missing...
Also, wondering how I can change the background color of the blocks now that they are coded differently than before? The don't seem to be in the portal.css anymore?
Pete
This is a problem of all prosilver Styles with a fixed small width. Since we just include the forumlist from the board, we have no bearing of its representation. Maybe you can force a minimum width of the center blocks... if you make it wider the error will disappear...
oldwillyswagons
How come it works in safari and older versions of firefox?
Pete
Because every Browser has its own Standarts and in every new Version they change them. ;)
