Your Portal Version: 1.0.4
Boardlink: http://www.mostly-harmless.org
PHP Version: 5
MySQL Version: 5.0
There is no real problem as yet, I'm trying to ascertain if there is likely to be a problem before I do something.
Searched the forums here, used Google, checked the Knowledge Base
I have a phpbb3 forum, that I have recently installed bbdkp on, I'd really like to replace the portal with the board3 portal and wanted to find out if I can just install board3 or if it's a lot of work.
bbdkp convert to board3
- phpBB.com User: Thresherinc
Re: bbdkp convert to board3
Update to this...
I had a little nose around in the files and the install and came to the conclusion that it would install no problem.
I was right!
Phew!
Install the mod version checker dependency first and then install the portal.
After that edit your styles if you use a different one to prosilver and Robert's your mother's brother.
I was right!
Phew!
nice site u have there m8, one problem thou..... the portal page center blocks width is not right in internet explorer but it is in firefox possible error you've not noticed in your css file or something
Thanks for that, I would never have noticed, I don't use IE for anything other than work.talonos wrote:nice site u have there m8, one problem thou..... the portal page center blocks width is not right in internet explorer but it is in firefox possible error you've not noticed in your css file or something
It appears to be an issue with IE8, when I run it in compatibility mode it was correct.
I shall have a dig around in the css files.
