MySQL Upgrade
tommy gun
phpBB.com User: tommy gun
MySQL Upgrade
Post by tommy gun »
Your Portal Version: Board3 Por
Boardlink: http://aquariumfishforum.com
PHP Version: 3.5
Have been using Board3 Portal for months without any problems. Today the company I host with upgraded from MySQL 4 to MySQL 5 and my portal page comes up blank.
In ACP all the blocks are turned off. Turned them on and get the error:
SQL ERROR [ mysql4 ]
Duplicate entry 'portal_advanced_stat' for key 1 [1062]
SQL
INSERT INTO phpbb_portal_config (config_name, config_value) VALUES ('portal_advanced_stat', 0)
BACKTRACE
FILE: includes/db/mysql.php
LINE: 174
CALL: dbal->sql_error()
FILE: portal/includes/functions.php
LINE: 64
CALL: dbal_mysql->sql_query()
FILE: includes/acp/acp_portal.php
LINE: 378
CALL: set_portal_config()
FILE: includes/functions_module.php
LINE: 471
CALL: acp_portal->main()
FILE: adm/index.php
LINE: 78
CALL: p_master->load_active()
Hi all,
Sorry to bother you with this question but after a recent MySQL upgrade, I'm having a problem with my portal page. I do have some experience with phpbb but I'm not really confident enough to know what to do here so I thought I would ask before I get in too deep. If it matters, the rest of my board works fine after the upgrade.
Thanks for your time,
TG
