vistablue
vistablue
Demo
_block_config.html
<!--version $Id: _block_config.html v1.0.4 adapted by: Mike $ //-->
<!-- DEFINE $LR_BLOCK_H_L = '<div class="forabg"><div class="top"><div class="tl">&nbsp;</div><div class="tr">&nbsp;</div><div class="tm">&nbsp;</div></div><div class="ml"><div class="mr"><div class="mm"><ul class="topiclist"><li class="header"><dl class="icon"><dt style="padding-left: 5px; white-space: nowrap; margin-bottom: 0px; margin-top: -5px;">' -->
<!-- DEFINE $LR_BLOCK_F_R = '</div></div></div><div class="bottom"><div class="bl">&nbsp;</div><div class="br">&nbsp;</div><div class="bm">&nbsp;</div></div></div></div>' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="forabg"><div class="top"><div class="tl">&nbsp;</div><div class="tr">&nbsp;</div><div class="tm">&nbsp;</div></div><div class="ml"><div class="mr"><div class="mm"><ul class="topiclist"><li class="header"><dl class="icon">' -->
<!-- DEFINE $C_BLOCK_H_R = '</dl></li></ul><ul class="topiclist forums">' -->
<!-- DEFINE $C_BLOCK_F_L = '</ul>' -->
<!-- DEFINE $C_BLOCK_F_R = '</div></div></div><div class="bottom"><div class="bl">&nbsp;</div><div class="br">&nbsp;</div><div class="bm">&nbsp;</div></div></div></div>' -->
<!-- DEFINE $BLOCK_DISTANCE = '5px' -->
<!-- DEFINE $S_POSTBODY_TOP = 0 -->
no
Routloutlou
phpBB.com User: TugDual
Re: vistablue
Post by Routloutlou »
Hello,
I'm just install the portail, and my style is Vistablue ...
I've that you create the style for this portail, but I don't know were i'm change these code ?
Did I need to create a file >> _block_config.html and I put this in template ?
Thank's in advance :mrgreen:
Re: vistablue
Routloutlou wrote:Hello,
Yes :o
Routloutlou
Re: vistablue
Thank's a lot :D
I've seen after that my version was out ... Sorry :oops: :roll: :oops:
