Your Portal Version: 1.0.4
Boardlink: http://www.thebandofthehawk.com
Updated phpbb from 3.0.4 to 3.0.5
Updated Board 3 Portal from 1.0.2 to 1.0.4 using automod
nothing
Greetings,
First, I would like to say thank you for writing such a fantastic mod!
I recently updated to Board3 Portal 1.0.4 and would like to assign permissions in the Admin Control Panel so that a custom group can change the welcome message on the portal. However, when I go to ACP > Users and Groups tab > Groups' Permission > %Custom Group Name Here% > Select Type : Admin Permissions > *Advanced Permissions, I do not see any options for Board3 Portal.
I am a founder / full admin, and have no problems with the ACP > .MODS > Portal settings themselves. Is it possible an edit didn't get done somewhere or a DB value is out of whack from my recent upgrade? I would rather not make this person / group a founder just to be able to change the welcome message.
Thanks for your time!
Erik
ACP Permissions for Portal 1.0.4
Re: ACP Permissions for Portal 1.0.4
Once you are in the Advanced Permissions, you have to click on Misc.
Awesome, right in front of my face no less. Thanks for the help, I didn't catch that they were in there.
I kinda have the samme issue... I think?
When i update like general settings in acp portal panel, everything looks fine
no errors, and the changes take place (It looks like?) ...but the _db_ does not update?
The install part was smooth, with no issues?
Portal 1.0.4 / phpbb 3.0.5 --> http://www.win7pro.dk
I guess that it is a permission issue, but I'm not sure ?
There is obv something I'm missing
Any ideas anyone ?
regards
lasbas / win7pro.dk
Any ideas anyone ?
regards
lasbas / win7pro.dk
I found out, when i make changes/updates to the portal
then changes will write to a colum in db called "config_portal"
but the the portal view gets called from a db colum called "config"
I hope someone can help me solve this issue so i dont
have to uninstall the portal and try another... I like this one
