Create a block
Sebf
phpBB.com User: Sebf
Create a block
Post by Sebf »
Your Portal Version: 1.0.2
Boardlink: http://www.racegamers.com/phpBB3/
Hello
First, thank you for this great MOD.
Then I would create a custom block with php / mysql
So I made a copy of "latest_members" on. Php and. Html
I also changed the portal_body.html, but alas, I can not display any values in my query ....
Thanks in advance and sorry for my English
news_temps.php
* @package - Board3portal
* @version $Id: news_temps.php 325 2008-08-17 18:59:40Z kevin74 $
if (!defined('IN_PHPBB'))
   exit;
if (!defined('IN_PORTAL'))
   exit;
$sql = 'SELECT id, date, jeu, user	FROM a_news_tps	ORDER BY id DESC';
while($row = $db->sql_fetchrow($result))
	$template->assign_block_vars('news_temps', array(
		'S_SEARCH_ACTION'=> $row['user'],
		'USERNAME_FULL'=> $row['jeu'],
		'POSTER_POSTS'	=> $row['id'],
$db->sql_freeresult($result);
$template->assign_vars(array(
	'S_DISPLAY_NEWS_TEMPS' => true
news_temps.html
<!--version $Id: news_temps.html 344 2008-08-24 20:50:39Z kevin74 $ //-->
		<th><span style="float: left"><img src="{T_THEME_PATH}/images/portal/portal_top_poster.png" width="16px" height="16px" alt="" />&nbsp;Derniers Temps</span></th>
	<tr class="row1">
		<td>
			<span style="float:left;"><strong>{L_USERNAME}</strong></span>
			<span style="float:right;padding-right:10px;"><strong>{L_POSTS}</strong></span><br style="clear:both" />
			<!-- BEGIN news_temps -->
			<span style="float:left;"><img src="{T_THEME_PATH}/images/portal/portal_user.png" width="16px" height="16px" alt="" /></span>
			<span style="float:left; padding-left:5px; padding-top:2px;">{news_temps.USERNAME_FULL}</span>
			<span style="float:right;padding-right:10px; padding-top:2px;"><a href="{news_temps.S_SEARCH_ACTION}">{news_temps.POSTER_POSTS}</a></span><br style="clear:both" />
			<!-- END news_temps -->
Portal_body.html
<!-- INCLUDE portal/block/news_temps.html -->
Message in French :
Bonjour
D'abord, merci beaucoup pour ce superbe MOD.
Ensuite, je voudrais creer un block personnalisé avec du php/mysql
J'ai donc fait une copie de "latest_members", le .php et le .html
J'ai modifié aussi le portal_body.html, mais helas, je n'arrive pas a afficher aucune valeurs de ma requette ....
D'avance Merci et désolé pour mon anglais[/i]
Re: Create a block
You have to include news_temps.php into portal.php too ;)
BTW: I would recomment you to update your portal... as long as you wait with it, as much trouble you will have ;) (no update instructions)
Sebf
Re: Create a block
Post by Sebf »
Yes, I put it in the portal.php
if ($portal_config['portal_news_temps'])
	include($phpbb_root_path . 'portal/block/news_temps.'.$phpEx);
And alas, nothing appears in my block
For the new version, alas it is not in french on the support site http://forums.phpbb-fr.com
In French:
Oui, j'ai mis ca dans le portal.php
Et hélas, rien ne s'affiche dans mon block
Pour la nouvelle version, hélas elle n'est pas en francais sur le site de support Fr http://forums.phpbb-fr.com
Re: Create a block
Try:
instead of:
Because otherwise you would need to have a DB fiels named portal_news_temp and set it to "1" and i guess you haven't created it. ;)
With this solution the block is included in every case.
Bonne chance!
Sebf
Re: Create a block
Post by Sebf »
Thank you, is OK
1000 Thank you :D :D :D :D
Re: Create a block
De rien! ;)
