Your Portal Version: 1.0.2
Boardlink: http://vwarrior.co.cc
Had fully functional phpbb 3.0.5 plus board3portal 1.0.2.
Tried upgrade from 1.0.2 to 1.0.3, it doesn't appear to have changed anything.
I have a active forum /portal with 1.0.2, on my test site I attempted the 1.0.2 to 1.0.3 upgrade, I don't see any differences.  Unfortunately attempting something else on the test server, I messed up a bunch of phpbb files, so I deleted the whole test site.  I want to install 1.0.4 on a new fresh install of phpbb 3.0.5 on the test site, that should be easy.
However on the live site, can I uninstall 1.0.2 and replace it with 1.0.4?  Will there be issues with the mysql d/b, since there are portal tables in the d/b?
						1.0.2 to 1.0.3 upgrade problems
Re: 1.0.2 to 1.0.3 upgrade problems
I didn't think this was a tough question.can I uninstall 1.0.2 and replace it with 1.0.4? Will there be issues with the mysql d/b, since there are portal tables in the d/b?
I wanted to do this, this weekend, and again, questions requesting support just SIT, with no response???????
I am sorry that I am whining so much.
Dont you think we have a real life too?
However, of course you can uninstall 1.0.2 and make a fresh install of 1.0.4
But the uninstaller just delete the database, but not all the edit you've done in the core files when you installed 1.0.2
Uninstaller? What uninstaller? You say just delete the d/b, I can't delete the d/b, my users are in the d/b.Mike wrote: But the uninstaller just delete the database,
Do you mean delete the portal table in the d/b?
The installer included in the portal package also works as an uninstaller.
Sorry, i mean the portal Table in the db and not the whole db
