Your Portal Version: 1.2
Which file contains the link to the navigation links at the top.
Portal & Board Index,  I have forgotten where they went.
I thought it was breadcrumbs.html but unfortunately couldn't find the a tag to the portal.php file.
						Simple file question?
Re: Simple file question?
If you use a subsilver2 based Style, then you are right with breadcrumbs.html
If you use a Style, based on prosilver, you have to edit overall_header.html and overall_footer.html
