Recent & Random Images
Foxy
phpBB.de User: Foxy
phpBB.com User: fujcube
Post by Foxy »
Your Portal Version: 1.0.3
Boardlink: http://www.border-forums.com
Nothing. This is a fresh install.
Nothing
My apologies if this is in the wrong section.
I'm looking for the mod that will display Recent & Random images from my phpBB Gallery (v 1.0.2)
Regards
Re: Recent & Random Images
Foxy wrote:...from my phpBB Gallery (v 1.0.2)
But please update prior to the phpBB Gallery v1.0.3
Foxy
phpBB.de User: Foxy
Post by Foxy »
Christian,
Do you mean that I have to upgrade my phpBB Gallery to 1.0.3, then download and install the Gallery Block v1.4.0
Regards
Foxy
Foxy wrote:Do you mean that I have to upgrade my phpBB Gallery to 1.0.3, then download and install the Gallery Block v1.4.0
correct
Foxy
phpBB.de User: Foxy
Post by Foxy »
Christian,
I have just had a look at phpBB Projekt and like the way in which the Recent & Random images are displayed in the small blocks on the portal. I notice that the Gallery Block is now at 1.4.1 and the Portal at 1.0.4
So as to bring my site up to date, would I be correct in saying that I need to upgrade my Portal from 1.0.3 to 1.0.4, my Gallery from 1.0.2 to 1.0.3, then install the Gallery Block 1.4.1
As I am having someone upgrade and install the upgrades for me, I need to make sure I give them the correct files. If incorrect, please can you detail which files I need to upgrade.
Your time and patience is very much appreciated.
Kindest Regards
Foxy
