just followed the online help install file
General Error
SQL ERROR [ mysqli ]
Table 'discover_forumss.PORTAL_CONFIG_TABLE' doesn't exist [1146]
An SQL error occurred while fetching this page
Hi ive got a problem with this above error
ive been following this install
portal_docs/install.xml
for the last 2hrs verry carfull not to go wrong but when i got to the end there was no
Browse to install/ and run the installer in my folders
and now our site is giving the above error
any help about this would be great thanks in advance
Re: Table 'discover_forumss.PORTAL_CONFIG_TABLE' doesn't exist [
- phpBB.de User: KaliMist
- phpBB.com User: KaliMist
i dont suppose there is a certain part in the instructions that this error refers to or do you need to go through the full lot again ?
thanks for the speedy reply aswell
also in some folders there seems to be duplicates of the same file
even though i deleted the old files one at a time after each one was updated
- phpBB.de User: dokkie
- phpBB.com User: dokkie
Hi kali can I help, in any way?
did u think of the forum style. or doens't that metter
