ElementBlack
Styles Anpassungen / Aufträge bitte hier veröffentlichen.
Styles adjustments / requests, please post here.
extreme-net
phpBB.com User: thxam
ElementBlack
Post by extreme-net »
I'm running a forum with 3 different themes (x-treme, prosilver and ElementBlack) both prosilver en x-treme themes are fine but the ElementBlack looks not good after installing the portal.
index looks fine like this
portal looks like this.
overall_header
<head>
{META}
// <![CDATA[
<!-- IF S_USER_PM_POPUP -->
	if ({S_NEW_PM})
	if (!name)
		name = '_popup';
	return false;
function jumpto()
	var per_page = '{PER_PAGE}';
* Find a member
function find_username(url)
	return false;
* Mark/unmark checklist
	if (!parent)
	if (!parent)
		return;
			rb[r].checked = state;
<!-- IF ._file -->
	function play_qt_file(obj)
		if (rectangle)
			var width = 200;
			var height = 0;
		obj.width = width;
		obj.height = height + 16;
		obj.Play();
function selectCode(a)
   // Get ID of code block
   var e = a.parentNode.parentNode.getElementsByTagName('CODE')[0];
   // Not IE
   if (window.getSelection)
      var s = window.getSelection();
      // Safari
      if (s.setBaseAndExtent)
         s.setBaseAndExtent(e, 0, e, e.innerText.length - 1);
      // Firefox and Opera
         var r = document.createRange();
         r.selectNodeContents(e);
         s.removeAllRanges();
         s.addRange(r);
   // Some older browsers
   else if (document.getSelection)
      var s = document.getSelection();
      s.addRange(r);
   // IE
   else if (document.selection)
      var r = document.body.createTextRange();
      r.moveToElementText(e);
      r.select();
</script>
<script type="text/javascript" src="{T_THEME_PATH}/highslide/highslide-full.js"></script>
	hs.graphicsDir = '{T_THEME_PATH}/highslide/graphics/';
	hs.align = 'center';
	hs.transitions = ['expand', 'crossfade'];
	hs.outlineType = 'glossy-dark';
	hs.fadeInOut = true;
	//hs.dimmingOpacity = 0.75;
	// Add the controlbar
	if (hs.addSlideshow) hs.addSlideshow({
		//slideshowGroup: 'group1',
		interval: 5000,
		repeat: false,
		useControls: true,
		fixedControls: true,
		overlayOptions: {
			opacity: .6,
			position: 'center center',
			hideOnMouseOut: true
</script>
</head>
<a name="top"></a>
<table class="wrap" width="100%" cellpadding="0" cellspacing="0">
<tr><td>
<div id="wrapheader">
		<table width="100%" cellpadding="0" cellspacing="0">
			<td width="413" height="90" style="background:url('{T_THEME_PATH}/images/topl.png');"><div class="logo"><a class="headw" href="{U_INDEX}">{SITE_LOGO_IMG}</a><br /><span class="genmedw">{SITE_DESCRIPTION}</span></div></td>
            <td height="90" style="background:url('{T_THEME_PATH}/images/topm.png');">&nbsp;</td>
            <td width="264" height="90" align="right" style="background:url('{T_THEME_PATH}/images/topr.png');">
	<div class="midlink">
	<div id="search-box">
            <fieldset class="nb">
               <input name="keywords" type="text" class="inputbox search" id="keywords" title="{L_SEARCH_KEYWORDS}" onblur="if(this.value=='')this.value='{LA_SEARCH_MINI}';" onclick="if(this.value=='{LA_SEARCH_MINI}')this.value='';" value="<!-- IF SEARCH_WORDS-->{SEARCH_WORDS}<!-- ELSE -->{L_SEARCH_MINI}<!-- ENDIF -->" maxlength="50" />
               <input class="nb" name="submit" type="hidden" /><br />
	<a class="genmedw" href="{U_SEARCH}" title="{L_SEARCH_ADV_EXPLAIN}">{L_SEARCH_ADV}</a> {S_SEARCH_HIDDEN_FIELDS}
            </fieldset>
	</form>
		<tr><td width="26" style="background:url('{T_THEME_PATH}/images/midl.png');"></td>
        <td class="inner">
			<td height="24" align="left">
	<div class="buttonwrapper">
	<div class="navspacel"></div>
	<!-- IF S_USER_LOGGED_IN -->
	<!-- ELSEIF S_REGISTER_ENABLED -->
	<a class="squarebuttonl" href="{U_REGISTER}"><span>{L_REGISTER}</span></a><div class="navspacel"></div>
	<a class="squarebuttonl" href="{U_PROFILE}"><span>{L_PROFILE}</span></a><div class="navspacel"></div>
	<!-- IF S_DISPLAY_PM -->
	<a class="squarebuttonl" href="{U_PRIVATEMSGS}"><span>{PRIVATE_MESSAGE_INFO}</span></a><div class="navspacel"></div>
	<a class="squarebuttonl" href="{U_RESTORE_PERMISSIONS}"><span>{L_RESTORE_PERMISSIONS}</span></a>
	<td width="431" height="24" align="right">
	<div class="navspacer"></div>
	<!-- IF not S_IS_BOT -->
	<a class="squarebuttonr" href="{U_LOGIN_LOGOUT}"><span>{L_LOGIN_LOGOUT}</span></a><div class="navspacer"></div>
	<a class="squarebuttonr" href="{U_MEMBERLIST}"><span>{L_MEMBERLIST}</span></a><div class="navspacer"></div>
	<a class="squarebuttonr" href="{U_FAQ}"><span>{L_FAQ}</span></a>
	<div id="datebar">
			<!-- IF S_BOARD_DISABLED -->
            <tr><td class="gensmall">
			<span class="error">{L_BOARD_DISABLED}</span>
            </td></tr>
			<!-- INCLUDE prime_quick_style.html -->
<div id="wrapcentre">
	<!-- IF S_DISPLAY_SEARCH -->
	<p class="searchbar">
	</p>
	<br style="clear: both;" />
<!-- INCLUDE announcement_centre.html -->
any help would be much appreciated.
greetings en thanks in advance,
extreme-net
Re: ElementBlack
Contrary to the description on phpbbstyles.net, this style is NOT base on prosilver but subsilver2.
Therefore you have to use the install instructions and files for subsilver2 ;)
extreme-net
Re: ElementBlack
Mike wrote:Contrary to the description on phpbbstyles.net, this style is NOT base on prosilver but subsilver2.
I used the subsilver install instruction and the subsilver files even do the results are as you can see.
Re: ElementBlack
Oh, ok... It seems you have done wrong edits in your overall_header...
You can take my overall_header.html:
demo: http://area51.mikevil.de/portal.php?style=65
<head>
{META}
// <![CDATA[
	if ({S_NEW_PM})
	if (!name)
		name = '_popup';
	return false;
function jumpto()
* Find a member
	return false;
	if (!parent)
	if (!parent)
		return;
<!-- IF ._file -->
		if (rectangle)
			var width = 200;
			var height = 0;
		obj.width = width;
		obj.Play();
   // Not IE
      // Safari
         s.addRange(r);
      s.addRange(r);
   // IE
      r.select();
</script>
</head>
<a name="top"></a>
<tr><td>
			<td width="413" height="90" style="background:url('{T_THEME_PATH}/images/topl.png');"><div class="logo"><a class="headw" href="{U_INDEX}">{SITENAME}</a><br /><span class="genmedw">{SITE_DESCRIPTION}</span></div></td>
            </fieldset>
	</form>
        <td class="inner">
	<div id="datebar">
            </td></tr>
	</p>
I made a new config, so it looks way better as with the original subsilver2 config ;)
viewtopic.php?f=42&t=2726
extreme-net
Re: ElementBlack
thx for your help.
just minutes before you posted your overall_header i fixed the problem.
I just needed to find the right place for this theme to place to place this line "<!-- IF not $S_IN_PORTAL or S_DISPLAY_PHPBB_MENU -->"
anyway thank you very much for your help.,
extreme-net
Return to “Style requests”
