Black Smoke Style
- phpBB.de User: blast
- phpBB.com User: blast
Black Smoke Style
Hello im starting a gaming community called Solid-Gaming.com I been searching for a style to start with and i stumbled upon this and i love it i was wondering if you could make this a portal style please
http://www.awesomestyles.com/phpbb3-sty ... lack-smoke phpbb3 3.0.4
Re: Black Smoke Style
why hasnt one person replied ?????????? ![Frage :?:](./images/smilies/icon_question.gif)
Install it just like prosilver, and use the prosilverfiles.
What you need is a config file, which ill post the next days...
Im not very good with this installing mods stuff i was wondering if you could help me or make the portal for me ??
I couldnt make a Portal for you, but i can adapt the needed files for this Style, and post it here...
But this needs a few days, cause im very busy at this time...![Zwinkern ;)](./images/smilies/icon_e_wink.gif)
I have have attemped to install the portal mod 1.2.2 and have failed three times now and cant seem to get this shit goin lol
Are you sure you use our Portal? Cause our latest Version is 1.0.3.blastman wrote:I have have attemped to install the portal mod 1.2.2
Maybe you should download the right version, and give it another try
I have researched and found that 1.2.2 is the newest version of the portal out there and that 1.0.3 is out of date according to http://www.phpbb3portal.com/ am i correct ?
No, its not ![Zwinkern ;)](./images/smilies/icon_e_wink.gif)
phpbb3portal is not the same as Bord3 Portal.
oh ok so which is better ? and which is more up to date mike ? i def want to use the best thats out there ![Lächeln :)](./images/smilies/icon_e_smile.gif)
You are here, so why dont you use our portal ![Zwinkern ;)](./images/smilies/icon_e_wink.gif)
And yes, we are up to date
Ok i have tryed installing this portal and i have followed the install.xml to the "t" lol and im coming up with this error
template->_tpl_load_file(): File ./styles/BlackSmoke/template//portal/portal_body.html does not exist or is empty
Did you upload all the files?
I have the portal working fine on prosilver now i just cant get it to work with the blacksmoke style and i have installed everything in the zip file cept the contrib and the modx.prosilver.en.exl could you help me get this portal mod working on the blacksmoke style mike much thanks bro
You have to copy the files from our download to this stylefolder.
It means, if your style is based on prosilver, you have to copy all the style files from our prosilver folder into your Stylefolder.
Then there will be the file portal.body.html which is actually missing![Zwinkern ;)](./images/smilies/icon_e_wink.gif)
After that you have to try to adapt this files, till the portal fits into the board. Buit the missing file error can be solved with copying the files...
