Aero Red
- phpBB.de User: Pharao50
- phpBB.com User: Pharao50
Aero Red
Hallo ich hätte gerne ein Portal für den Style:
Aero Red,
Aero Blue,
Aero Green,
und Aero Black
Hier der Link:
http://www.phpbbhq.com/viewtopic.php?f=4&t=2
Danke schon mal im Voraus
Ich weiß eure Arbeit echt zu schätzen is echt klasse
Pharao50
Aero Red,
Aero Blue,
Aero Green,
und Aero Black
Hier der Link:
Pharao50
Re: Aero Red
Re: Aero Red
will it work on red then?
Re: Aero Red
tried it, file edits for overall_header.html
are different, cant find some of the classes in files red and blue must be diff????
unless the version i have has ben updated?
html for overall_header
<head>
{META}
// <![CDATA[
<!-- IF S_USER_PM_POPUP -->
if ({S_NEW_PM})
if (!name)
name = '_popup';
return false;
function jumpto()
var perpage = '{PER_PAGE}';
* Find a member
function find_username(url)
popup(url, 850, 570, '_usersearch');
return false;
* Mark/unmark checklist
if (!parent)
if (!parent)
return;
rb[r].checked = state;
<!-- IF ._file -->
function play_qt_file(obj)
if (rectangle)
var width = 200;
var height = 0;
obj.width = width;
obj.height = height + 16;
obj.Play();
</script>
</head>
<a name="top"></a>
<div id="wrapheader">
<table width="100%" border="0" align="center" cellpadding="0" cellspacing="0" style="background:url('{T_THEME_PATH}/images/top.png');">
<td height="42">
<div class="toplink">
<!-- IF not S_IS_BOT -->
<!-- IF S_USER_LOGGED_IN -->
<!-- IF S_DISPLAY_PM -->
<span class="genmedw"><a class="genmedw" href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}<!-- IF PRIVATE_MESSAGE_INFO_UNREAD -->, {PRIVATE_MESSAGE_INFO_UNREAD}<!-- ENDIF --></a></span>
</div></td>
<td height="32" align="right">
<!-- IF not S_USER_LOGGED_IN --><span class="genmedw"><a class="genmedw" href="{U_REGISTER}">{L_REGISTER}</a> • </span><!-- ENDIF -->
<span class="genmedw"><a class="genmedw" href="{U_LOGIN_LOGOUT}">{L_LOGIN_LOGOUT}</a></span>
<table width="100%" border="0" align="center" cellpadding="0" cellspacing="0" style="background:url('{T_THEME_PATH}/images/mid.png');">
<td height="80"><div class="midlink"><span class="headw"><img src="{T_THEME_PATH}/site_logo.jpg"></span><br /><span class="genmedw">{SITE_DESCRIPTION}</span></div></td>
<td height="80" align="right">
<div id="search-box">
<fieldset class="nb">
<input name="keywords" style="opacity:0.7;filter:alpha(opacity=70)" onmouseover="this.style.opacity=1;this.filters.alpha.opacity=100" onmouseout="this.style.opacity=0.7;this.filters.alpha.opacity=70" type="text" class="inputbox search" id="keywords" title="{L_SEARCH_KEYWORDS}" onblur="if(this.value=='')this.value='{LA_SEARCH_MINI}';" onclick="if(this.value=='{LA_SEARCH_MINI}')this.value='';" value="<!-- IF SEARCH_WORDS-->{SEARCH_WORDS}<!-- ELSE -->{L_SEARCH_MINI}<!-- ENDIF -->" maxlength="50" />
<input class="nb" name="submit" type="image" src="{T_THEME_PATH}/images/search.png" align="absmiddle" /><br />
{S_SEARCH_HIDDEN_FIELDS}
</fieldset>
</form>
<table width="100%" border="0" align="center" cellpadding="0" cellspacing="0" style="background:url('{T_THEME_PATH}/images/bottom.png');">
<td class="genmedw" height="42" align="left">
<div class="bottomlink">
<!-- IF S_USER_LOGGED_IN --><a class="genmedw" href="{U_PROFILE}">{L_PROFILE}</a><!-- ENDIF -->
<!-- IF U_RESTORE_PERMISSIONS --> <a class="genmedw" href="{U_RESTORE_PERMISSIONS}">{L_RESTORE_PERMISSIONS}</a><!-- ENDIF -->
<!-- IF S_BOARD_DISABLED and S_USER_LOGGED_IN --> • <span style="color: red;">{L_BOARD_DISABLED}</span><!-- ENDIF -->
<td class="genmedw" align="{S_CONTENT_FLOW_END}">
<div class="bottomlink"><span class="genmedw">
<a class="genmedw" href="{U_FAQ}">{L_FAQ}</a><!-- IF not S_IS_BOT --><!-- IF S_DISPLAY_MEMBERLIST --> • <a class="genmedw" href="{U_MEMBERLIST}">{L_MEMBERLIST}</a><!-- ENDIF --><!-- IF S_DISPLAY_SEARCH --> • <a class="genmedw" href="{U_SEARCH}">{L_SEARCH}</a><!-- ENDIF --><!-- ENDIF -->
</span>
<div id="datebar">
<div id="wrapcentre">
<p class="searchbar">
</p>
<br style="clear: both;" />
Re: Aero Red
Maybe there are newer versions of Aero Styles...
We will update our Styles if 1.0.4 is released.
Re: Aero Red
im not sure,
i inherited the site that was custom built by someone else, not sure if they modified the style
and had to move it from IIS to unix as had lots of cgi errors.!!!
anyway
could someone look at the file edits for that template code and point me in the right direction??
thanks
or point me to a tutorial on how to port the style for a portal???
anyway
thanks
Re: Aero Red
i installed the latest areored style and and then added the portal styles using the edits for aeroblue......it almost works, but not quite
there are a few layout errors (no other =mods installed apart form a homepage link mod)
one problem is that the width of the forum boxes displayed is very wide??
(cant show image as doing on xammp)
Re: Aero Red
trying to make this work as well. included an image so you can see whats going on - gonna keep cracking away at it.
Re: Aero Red
Managed to clean up some of the stylesheet issues with the news section (the topic title was unreadable). I essentially ditched the cellpic they had and just locked the news to 1 row scheme (they had alternating row schemes based on the topic row number). Still trying to figure out the cell spacing issues. Screenshot to show my progress, let me know if you want the code and ill be willing to share the changes i made.
Re: Aero Red
Dont you want the Frames around the Blocks? http://area51.mikevil.de/portal.php?style=4
If you use B3P 1.0.3 you can use this config and instructions to get the frames.
viewtopic.php?f=42&t=2077
If you are up to date and use 1.0.4 you have to use this config:
<!--version $Id: _block_config.html 544 2009-09-10 12:35:25Z christian_n $ //-->
<!-- DEFINE $LR_BLOCK_H_L = '<table width="100%" border="0" cellpadding="0" cellspacing="0"><tr><td width="18" height="18"><img src="./styles/AeroBlack/theme/images/tl.png" width="18" height="18" alt="" /></td><td height="18" style="background:url(./styles/AeroBlack/theme/images/tm.png);"></td><td width="18" height="18"><img src="./styles/AeroBlack/theme/images/tr.png" width="18" height="18" alt="" /></td></tr><tr><td width="18" style="background:url(./styles/AeroBlack/theme/images/ml.png);"></td><td><table class="tablebg" cellspacing="0" width="100%"><tr><th><span style="float: left">' -->
<!-- DEFINE $LR_BLOCK_H_R = '</span></th></tr></table>' -->
<!-- DEFINE $LR_BLOCK_F_R = '</td><td width="18" style="background:url(./styles/AeroBlack/theme/images/mr.png);"></td></tr><tr><td width="18" height="18" align="right"><img src="./styles/AeroBlack/theme/images/bl.png" width="18" height="18" alt="" /></td><td height="18" style="background:url(./styles/AeroBlack/theme/images/bm.png);"></td><td width="18" height="18"><img src="./styles/AeroBlack/theme/images/br.png" width="18" height="18" alt="" /></td></tr></table>' -->
<!-- Config for the center blocks // -->
<!-- DEFINE $C_BLOCK_H_L = '<table width="100%" border="0" cellpadding="0" cellspacing="0"><tr><td width="18" height="18"><img src="./styles/AeroBlack/theme/images/tl.png" width="18" height="18" alt="" /></td><td height="18" style="background:url(./styles/AeroBlack/theme/images/tm.png);"></td><td width="18" height="18"><img src="./styles/AeroBlack/theme/images/tr.png" width="18" height="18" alt="" /></td></tr><tr><td width="18" style="background:url(./styles/AeroBlack/theme/images/ml.png);"></td><td><table class="tablebg" cellspacing="0" width="100%"><tr><th><span style="float: center">' -->
<!-- DEFINE $C_BLOCK_H_R = '</span></th></tr></table>' -->
<!-- DEFINE $C_BLOCK_F_R = '</td><td width="18" style="background:url(./styles/AeroBlack/theme/images/mr.png);"></td></tr><tr><td width="18" height="18" align="right"><img src="./styles/AeroBlack/theme/images/bl.png" width="18" height="18" alt="" /></td><td height="18" style="background:url(./styles/AeroBlack/theme/images/bm.png);"></td><td width="18" height="18"><img src="./styles/AeroBlack/theme/images/br.png" width="18" height="18" alt="" /></td></tr></table>' -->
<!-- DEFINE $BLOCK_DISTANCE = '0' -->
Re: Aero Red
thanks a bunch mike.
Re: Aero Red
did you get it working fourth?
i would like the edits if thats ok
regards
rob
regards
rob
Re: Aero Red
robgib: read my last posting.. There are the edits
- Valued Contributor
- phpBB.de User: blast
- phpBB.com User: blast
Re: Aero Red
Maybe im missing somthing but i downloaded th aero red styles and tryed to install portal 1.0.4 and i cant find any of the Overall_header.html edits am i missing something ??
