Your Portal Version: 1.0.03
Boardlink: http://forums.service--manuals.co.uk
I have spent all week reading up on the forum.
I installed phpbb3 on my business server.
I installed your great Portal.
All worked OK.
I used bigdump to install a full backup from my current forum host.
This was OK as a guest but login and I get SQL errors because my forum backup was done with aeroblue as default.
I installed your aeroblue files.
Everything is now working, full forum, portal works great. No problems at all, except one.
In the ACP there is no Portal/Mod tab.
I looked and the Mod tab is enabled.
Nothing yet.
I am too scared to mess around with it as it is nearly perfect in everyway.
Please can someone tell me what I have to do to get the Portal/Mod tab to appear in the ACM
I have spent so much time on this and I am very close to having it perfect.......
Mod/Portal Tab is Missing in ACP
Re: Mod/Portal Tab is Missing in ACP
This is what I did to solve the problem.
Went to phpmyadmin and deleted the portal_config file in my database.
I then put the Portal install folder back on the server.
I then browsed to my website/install/
The installer ran perfectly with no errors.
I deleted the install folder from the server.
Now every thing is Perfect
I have the mods tab back in the ACP.
I am now very happy indeed.
Moral of the story seems to be make sure you have the correct styles etc in place before you run the installer...
regards
Trevor
regards
Trevor
I have the same problem. But Im not as good on this.
Where do I find this config file?
You can add the portal manually by doing:
ACP -> System -> Module management -> Administration Control Panel -> .MODS
Create new module -> Portal
Click Portal
Find Portal [acp_portal] in the drop down on the bottom right, for every option under the heading Portal click add module.
Make sure .MODS, Portal and all modules under that are enabled.
Click Portal
