Your Portal Version: 1.0.3
Your phpBB Type: other phpBB Distribution
Everything was fine : Board3 1.0.2 works fine
Disable Portal from ACP
I upgraded to Board3 to 1.0.3 ,the installation was Ok.
When the user is logged : The position of blocks are Ok !
But when not logged :
Problem position of block -Aeroblue
Re: Problem position of block -Aeroblue
That fixes your errors: http://board3deportal.svn.sourceforge.n ... vision=499
Works perfectly !
Thanks Marc
Thanks Marc
