DVGFX2
xWhistler
DVGFX2
Post by xWhistler »
Your Portal Version: 1.0.3
Boardlink: http://www.vereornos.com
installed the DVGFX2 theme to the forum and follwed instructions to make it work with the portal.
followed the instructions...
Everything works great other then when you log out and visit the site as a guest the right blocks fall to the bottom of the page like they are center blocks. If you login to the site the problem is no longer there.....
any ideas why the portal does not display right for guest?
pirateorion
Re: DVGFX2
Post by pirateorion »
MODs installed: Version requisite
Boardlink: http://www.arcasd.com
problem occured after full install copleted of board3 and DVGFX2 style and admin began to alter forum structure.
reinstall from scratch, double check MySQL entries, edit portal_body and _block_config
Same as above where blocks are not aligned properly, although it persists regardelss of whether you are a guest or not.
Re: DVGFX2
xWhistler wrote:Your Portal Version: 1.0.3
As I said to you, it is seen in the styles prosilver no errors. http://vereornos.com/Community/portal.php?style=1
But subsilver2 errors. http://vereornos.com/Community/portal.php?style=6
Maybe it is not based on subsilver2 (your styles basis) or you have errors during the installation done.
Note board3portal_1_0_3 \ contrib \ subsilver2.xml
und B3P_DVGFX2\install.xml
My Demo: klick hier
xWhistler
Re: DVGFX2
Post by xWhistler »
I will try to re-install that style and see what happens...
Return to “Styles Support”
