Boardlink: http://malevolent-guild.org
nothing new install
i double checked all the modded php files
i uploaded all the files i have double check them all to make sure they are modded correctly when i goto http://malevolent-guild.org/install/index.php or http://malevolent-guild.org/install/install_main.php i get the error The server encountered an unexpected condition which prevented it from fulfilling the request.
The script had an error or it did not produce any output. If there was an error, you should be able to see it in the error log.
install error
