Boardlink: http://www.conquesteu.com/portal.php
Tried to add a custom page (about us) into a centre block with link on menu which then goes to that page. That page displays my content but keeps the full portal and style.
The problem I had was that it would not carry my style.
I followed a guide which was wrote in German but it was hard to follow as the google translator just gave broken english.
I basically want to add a link to the menu which displays a custom center block on my portal, it should keep all the styles and it would be nice if the content looked like the Latest News block and kept the nice borders.
Example.
I click About Us and portal page opens About Us content in the center, it keeps all the nice style as well.
Adding page to centre block.
Re: Adding page to centre block.
can you post the link to that german guide?
have you tried adding something like this to your custom box html
Replacing the with the proper formating to link to your own stylesheet
<link rel="stylesheet" href="/styles/wow_alliance/theme/stylesheet.css" media="all">Code: Select all
/styles/wow_alliance/theme/Re: Adding page to centre block.
First of all let me say hi. Hi to all
Ok im quite new to all of this but im a quick learnen and like to experiment wich basicly means im uploading backups more then you ever can think of.
I recently stumbled acros this topic wich just answered my needs.
Im dumbting the same issue's. Not the style part but the how to.
How can i add a custom made html file to be called uppon when pressed in the menu.
I've added a menu item (lets call it units) and when visitors press the link (a href="units.html") then the custom made center block should appear in the portal (so it looks like left block - center unit block only - right block)
Kinda like basic html. You hard code a menu list with a href's and br's where you call a certain html files into iframes.
Now i know board3 portal just calls certain info out of the dbase made in phpbb but what just was wondering.
The alternative i thought of was calling them into a _blank page. But i would like to still have the portal intact while making it into a frontpage.
By all means share your thought and howto's cause im kinda stuck here in idea's.
ps: im sorry for my poor eng .. well guess you heared if all before
to get this to work like u say, you'd have to combine 2 things together
phpbb info for setting up a custom page
and also
Portalview
which is "display portal on all pages of forum"
and also
Portalview
Thanks talonos .. not the answer i was searching on but you pushed me into a new direction.
