Boardlink: http://www.fororcdespanyol.com
Trying to find how to delete these blocks from my website.
Go to the PORTAL seccion into the ACP zone, but i can not find where to desactivate these blocks.
I don't know how to desactivate these blocks from the portal page. I don't find the window configuration into the ACP zone where you can select or not these blocks. Basiclly, what I want is a right main row to gain space; with the user menu and few blocks more. Is it possible to add or delete all the blocks but only from the right row?
Here you can find an example: fororealmadrid.com and allows only to write the latest news and recent posts.
Thank you, and hope you understend what i mean.
Regards.
Add/delete blocks with one row
MrBaseball34
- Valued Contributor
- phpBB.de User: MB34
Re: Add/delete blocks with one row
After installing, the configuration page for the Portal should be on the .MODS tab of the ACP.
There you can enable/disable all the blocks you want as well as configure them by clicking on them in the left menu.
MrBaseball34
Hook 'em Horns
2005 College Football National Champions
2005 College Baseball National Champions
Hook 'em Horns
