Boardlink: http://www.gankedwow.com
The page just showed up with no issues then over night it went blank
I removed the redirect
I was looking at it before I went to bed and when I got up the next morning to check something on it the page was white and the only thing working was the forum pages.  Everything else is working just fine just not the portal.php.  I have it enabled so you can see for yourself when you go to the web site.
						Portal suddenly white
Re: Portal suddenly white
I just reinstalled the portal and it's working fine again.
