'SubSilver2' not working correctly
ForumHoster
Post by ForumHoster »
Boardlink: http://bla.forum-hoster.nl
PHP Version: 3.0.5
Nothing, I just edited the necessary files for the 'subsilver2' style.
I already tried the 'subsilver2.xml' file (later, I found out that I must use this file to edit 'subsilver2') and I tried to clear the cache (which didn't solved the problem).
Hi there ^^
I'm running a (Dutch) forum hosting service and I installed your portal software (Board3). And because I'm running a forum hosting service, I have a lot of styles installed for users to choose between, including 'subsilver2'. Now, I edited 'subsilver2' according to the 'subsilver2.xml' file, but the portal is still messed up.
Any ideas how to solve this?
Thanks in advance.
Re: 'SubSilver2' not working correctly
Your Link doesnt work...
ForumHoster
Now it does ;) Sorry for the down-time. Our providers sucks, so we're searching for a new one ;)
BTW: I installed the style-changer and installed all styles I have on the server. And most of the styles aren't working correctly with the portal. That's weird, because I eddited everyting according to the 'install.xml' file (prosilver-based styles) and the 'subsilver2.xml' file (subsilver2-based styles).
For subsilver2 Styles you have to copy the subsilver2 files instead of the files from prosilver. ;)
ForumHoster
Ah, problem solved :D I'm such a noob for not seeing that -.- Anyway, now I can be a pro forum host again :D
Thanks alot!
