Found and corrected SQL Bug
sailsfast
Post by sailsfast »
Your Portal Version: 1.0.3
MySQL Version: Postgres not MySQL
Installed Board3
edited files
ran install
Debugged SQL the error.
Presumably you might want to include this in your next release. :-)
After installing properly... Opening the portal resulted in this
SQL ERROR [ postgres ]
ERROR: for SELECT DISTINCT, ORDER BY expressions must appear in select list []
SQL
SELECT DISTINCT u.user_id, u.username, u.user_colour, u.user_allow_viewonline, MAX(s.session_time) as online_time, MIN(s.session_viewonline) AS viewonline FROM phpbb_users u, phpbb_zebra z LEFT JOIN phpbb_sessions s ON (s.session_user_id = z.zebra_id) WHERE z.user_id = 2 AND z.friend = 1 AND u.user_id = z.zebra_id GROUP BY z.zebra_id, u.user_id, u.username, u.user_allow_viewonline, u.user_colour ORDER BY u.username_clean ASC LIMIT 8 OFFSET 0
BACKTRACE
FILE: includes/db/postgres.php
LINE: 177
CALL: dbal->sql_error()
LINE: 232
CALL: dbal_postgres->sql_query()
FILE: includes/db/dbal.php
LINE: 170
CALL: dbal_postgres->_sql_query_limit()
FILE: portal/block/friends.php
LINE: 78
CALL: dbal->sql_query_limit()
FILE: portal.php
LINE: 243
CALL: include('portal/block/friends.php')
To RESOLVE the error
The select doesn't match....
Find FILE: portal/block/friends.php
Goto line 73
and change u.username_clean to u.username
OR
add:
in the preceding select statment[/i]
Re: Found and corrected SQL Bug
Thank you for report.
Fixed in SVN: http://board3deportal.svn.sourceforge.n ... athrev=522
