Serenity Dark Blue
Demo Link: http://www.phpbb.com/styles/demo/3.0/?style_id=36
Portal Demo : http://phpbb3styles.nl/portal.php?style=61
My problem is that the block image do not show up
Is there any solution to hanle it?
Style Request Serenity Dark Blue
Re: Style Request Serenity Dark Blue
Is it your Site (second Link) or what do you mean with the not showing images?
I mean that I want the portal page can be like the forum page
[every block images with a forum] <----> [every block images with a function of portal]
if it is not clear, please tell me
I do not know wether it is possible to do that
but without the block images
the page is very choas to me
Thanks for you attention
I don't know exactly what you mean... Should it look like that: http://area51.mikevil.de/portal.php?style=57?
Yes
That's right
I want my portal page look like that
But my page look like the second link of my first post
How can I improve it?
Thanks
That's right
Thanks
The Portal in the second link is very outdadet, so i dont wonder why it looks so weired And it seems the Admin dont adapt the styles there. He just Install it and leave it alone...
If you already moded your style you have to compare your code with mine and search the strings to add.
But if you don't have any Mods or adaptions in your Style, or if you don't have installed it you can do the following.
Install this Style, using subsilver2 files from our dl package and after that replace the next 3 Files with the code beneath.
overall_header.html:
breadcrumbs.html:
portal/_block_config.html:
<head>
<!-- INCLUDE ca_config.html -->
{META}
<title>{SITENAME} - <!-- IF S_IN_MCP -->{L_MCP} - <!-- ELSEIF S_IN_UCP -->{L_UCP} - <!-- ENDIF -->{PAGE_TITLE}</title>
// <![CDATA[
var ca_main_width = '{$CA_WIDTH}';
<!-- IF S_USER_PM_POPUP -->
if ({S_NEW_PM})
if (!name)
name = '_popup';
return false;
function jumpto()
var per_page = '{PER_PAGE}';
* Find a member
function find_username(url)
return false;
* Mark/unmark checklist
if (!parent)
if (!parent)
return;
rb[r].checked = state;
<!-- IF ._file -->
function play_qt_file(obj)
if (rectangle)
var width = 200;
var height = 0;
obj.width = width;
obj.height = height + 16;
obj.Play();
window.onload = function()
eval(onload_functions[i]);
window.onunload = function()
eval(onunload_functions[i]);
if(navigator.userAgent && navigator.userAgent.indexOf('Mac OS X') > 0)
document.write('<link rel="stylesheet" href="{T_THEME_PATH}/mac.css" type="text/css" />');
</script>
<script type="text/javascript" src="{T_TEMPLATE_PATH}/ca_scripts.js"></script>
</head>
<div id="wrapper">
<a name="top"></a>
<table border="0" cellspacing="0" cellpadding="0" width="{$CA_WIDTH}" id="maintable" align="center">
<td id="logorow" align="center">
<a href="{U_INDEX}">{SITE_LOGO_IMG}</a>
<td class="navtd">
<div class="navrow">
<div class="navrow-right">
<a href="{U_FAQ}">{L_FAQ}</a>
<!-- IF U_RESTORE_PERMISSIONS --> • <a href="{U_RESTORE_PERMISSIONS}">{L_RESTORE_PERMISSIONS}</a><!-- ENDIF -->
<!-- IF S_DISPLAY_SEARCH --> • <a href="{U_SEARCH}">{L_SEARCH}</a><!-- ENDIF -->
<!-- IF not S_IS_BOT -->
<!-- IF S_DISPLAY_MEMBERLIST --> • <a href="{U_MEMBERLIST}">{L_MEMBERLIST}</a><!-- ENDIF -->
<!-- IF not S_IS_BOT --> • <a href="{U_LOGIN_LOGOUT}">{L_LOGIN_LOGOUT}</a><!-- ENDIF -->
<!-- IF S_USER_LOGGED_IN --><a href="{U_PROFILE}">{L_PROFILE}</a><!-- ENDIF -->
<!-- IF S_DISPLAY_PM --> • <a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}</a><!-- ENDIF -->
<!-- ELSEIF S_REGISTER_ENABLED -->
<a href="{U_REGISTER}">{L_REGISTER}</a>
<td id="contentrow">
<!-- IF not S_IS_BOT && not $CA_SKIP_PM_NOTIFY && S_USER_LOGGED_IN && S_DISPLAY_PM -->
<!-- IF S_USER_NEW_PRIVMSG -->
<div class="pm-notify-new"><div class="pm-notify-header">{L_PRIVATE_MESSAGES}</div><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}<!-- IF PRIVATE_MESSAGE_INFO_UNREAD -->, {PRIVATE_MESSAGE_INFO_UNREAD}<!-- ENDIF --></a></div>
<!-- ELSEIF S_USER_UNREAD_PRIVMSG -->
<div class="pm-notify-unread"><div class="pm-notify-header">{L_PRIVATE_MESSAGES}</div><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}<!-- IF PRIVATE_MESSAGE_INFO_UNREAD -->, {PRIVATE_MESSAGE_INFO_UNREAD}<!-- ENDIF --></a></div>
<td class="gensmall">
<!-- IF S_USER_LOGGED_IN -->{LAST_VISIT_DATE}<br /><!-- ENDIF -->
<!-- IF S_DISPLAY_SEARCH --><a href="{U_SEARCH_UNANSWERED}">{L_SEARCH_UNANSWERED}</a> | <a href="{U_SEARCH_ACTIVE_TOPICS}">{L_SEARCH_ACTIVE_TOPICS}</a><!-- ENDIF -->
<td class="gensmall" align="{S_CONTENT_FLOW_END}">
{CURRENT_TIME}<br />
<!-- IF S_DISPLAY_SEARCH and S_USER_LOGGED_IN --><a href="{U_SEARCH_NEW}">{L_SEARCH_NEW}</a> | <a href="{U_SEARCH_SELF}">{L_SEARCH_SELF}</a><!-- ENDIF -->
<table class="tablebg breadcrumb" width="100%" cellspacing="{$CA_SPACING}" cellpadding="0" style="margin-top: 5px;">
<td class="row1">
<p class="breadcrumbs"><!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a> » <!-- ENDIF --><a href="{U_INDEX}">{L_INDEX}</a><!-- BEGIN navlinks --> » <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></p>
<p class="datetime">{S_TIMEZONE}</p>
<!--version $Id: _block_config.html 479 2009-03-15 11:19:27Z kevin74 $ //-->
<!-- DEFINE $LR_BLOCK_H_L = '<div class="cap-div"><div class="cap-left"><div class="cap-right">' -->
<!-- DEFINE $LR_BLOCK_H_R = '</div></div></div>' -->
<!-- DEFINE $LR_BLOCK_F_R = '<br />' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="cap-div"><div class="cap-left"><div class="cap-right" style="float: center">' -->
<!-- DEFINE $C_BLOCK_H_R = '</div></div></div>' -->
<!-- DEFINE $C_BLOCK_F_R = '<br />' -->
Thank you very much~
It works
And the page is very beautiful~!!
It works
