Help me Portal page white
Your Portal Version: 1.0.3
MODs installed: si
Your knowledge: little php
Excused if I speak badly English but are Italian. after l' installation of the portal me exited the page white woman because? you help me for pleasure
Per favore mi aiutate? sono italiano e l'inglese non lo capisco bene vi prego....
MODs installed: si
Re: Help me Portal page white
Sorry, but i read this about ten times, and now i have tears in my eyes because it sounds "a bit" funny
What i read is, that you have a problem with a white woman after installing the Portal...
Ok, since it makes no sence, i think this is what you looking for: knowledge/kb_show.php?id=3
![Zwinkern ;)](./images/smilies/icon_e_wink.gif)
![Verwirrt :?](./images/smilies/icon_e_confused.gif)
![Überglücklich :D](./images/smilies/icon_e_biggrin.gif)
Thanks pero' I have not understood in which rows I must control
P.S. you pardon to me if I write badly but they are of Rome (Italian)
No problem buddy... i just hope you can solve your problem now... ![Zwinkern ;)](./images/smilies/icon_e_wink.gif)
I have controlled all the modified rows but the page exits me always white help help as I make
UFFF...![Weinend oder sehr traurig :cry:](./images/smilies/icon_cry.gif)
UFFF...
You should clear your caches, but if you cannot access your ACP you can do it manualy... clear the content of the "cache" folder in the root of your Board. But dont delete the following two files:
- .htaccess
- index.html
- .htaccess
- index.html
My style glacier (v. php 3.0.4)
EDIT:
I have resolved thanks Mike Now pero' the portal exits to me along in horizontal I can put as it online?
Perche' the portal goes to me all on the right and does not exit me in all the page?
http://img513.imageshack.us/img513/9867/anonimo.jpg
EDIT:
Sorry, but i didnt understand correctly. can you provide a link to your board please?
http://img78.imageshack.us/img78/4224/screeniki.jpg
Con Firefox the portal not e' aligned, would want I it to all screen.
overall_header (style glacier)
It does not exist
Here is my overall_header.html from Glacier Style. Watch the Demo
Your Picture doesnt help, because i cannot debug it ![Zwinkern ;)](./images/smilies/icon_e_wink.gif)
<head>
{META}
phpBB style name: prosilver
Based on style: prosilver (this is the default phpBB3 style)
Original author: Tom Beddard ( http://www.subBlue.com/ )
Modified by: Ika - ShadowFlames Development
// <![CDATA[
var on_page = '{ON_PAGE}';
var per_page = '{PER_PAGE}';
<!-- IF S_USER_PM_POPUP -->
if ({S_NEW_PM})
var url = '{UA_POPUP_PM}';
* Find a member
function find_username(url)
return false;
window.onload = function()
eval(onload_functions[i]);
window.onunload = function()
eval(onunload_functions[i]);
</script>
<!--[if lt IE 7.]>
<script defer="defer" type="text/javascript" src="{T_TEMPLATE_PATH}/pngfix.js"></script>
<![endif]-->
</head>
<div class="outside">
<div class="top-left"></div><div class="top-center"></div><div class="top-right"></div>
<div class="inside">
<div class="notopgap"></div>
<div id="wrap">
<div id="header_nav">
<span class="preload1"></span>
<span class="preload2"></span>
<ul id="nav">
<!-- IF S_BOARD_DISABLED and S_USER_LOGGED_IN -->
<li class="top"><a href="{U_INDEX}" class="top_link"><span style="color: red;">{L_BOARD_DISABLED}</span></a></li>
<!-- IF not S_IS_BOT -->
<li class="top"><a href="{U_LOGIN_LOGOUT}" class="top_link"><span>{L_LOGIN_LOGOUT}</span></a></li>
<li class="top"><a href="{U_RESTORE_PERMISSIONS}" class="top_link"><span>{L_RESTORE_PERMISSIONS}</span></a></li>
<!-- IF S_USER_LOGGED_IN -->
<!-- IF S_DISPLAY_PM -->
<li class="top"><a href="{U_PRIVATEMSGS}" class="top_link"><span>{PRIVATE_MESSAGE_INFO}</span></a></li>
<li class="top"><a href="{U_REGISTER}" class="top_link"><span>{L_REGISTER}</span></a></li>
<li class="top"><a href="#" id="controlpanel" class="top_link"><span class="down">Control Panel</span><!--[if gte IE 7]><!--></a><!--<![endif]-->
<!--[if lte IE 6]><table><tr><td><![endif]--><ul class="sub">
<li><b>Users</b></li>
<li><a href="{U_PROFILE}" class="fly">{L_PROFILE}<!--[if gte IE 7]><!--></a><!--<![endif]-->
<!--[if lte IE 6]><table><tr><td><![endif]--><ul>
<li><a href="./ucp.php?i=163">Overview</a></li>
<li><a href="./ucp.php?i=164">Profile</a></li>
<li><a href="./ucp.php?i=165">Board Preferences</a></li>
<li><a href="./ucp.php?i=166">Private Messages</a></li>
<li><a href="./ucp.php?i=167">User Groups</a></li>
<li><a href="./ucp.php?i=168">Friends & Foes</a></li>
</ul><!--[if lte IE 6]></td></tr></table></a><![endif]-->
</li>
<!-- IF U_MCP -->
<li><b>Moderators</b></li>
<li><a href="{U_MCP}">{L_MCP}</a></li>
<!-- IF U_ACP -->
<li><b>Administrators</b></li>
<li><a href="{U_ACP}">{L_ACP}</a></li>
</li>
<li class="top"><a href="{U_INDEX}" id="forumlinks" class="top_link"><span class="down">Forum</span><!--[if gte IE 7]><!--></a><!--<![endif]-->
<li><b>Information</b></li>
<li><a href="{U_FAQ}">{L_FAQ}</a></li>
<!-- IF S_DISPLAY_MEMBERLIST --><li><a href="{U_MEMBERLIST}">{L_MEMBERLIST}</a></li><!-- ENDIF -->
<li><b>Manage</b></li>
<!-- IF not S_IS_BOT and U_MARK_FORUMS --><li><a href="{U_MARK_FORUMS}">{L_MARK_FORUMS_READ}</a></li><!-- ENDIF -->
<!-- IF not S_IS_BOT and U_MARK_TOPICS --><li><a href="{U_MARK_TOPICS}">{L_MARK_TOPICS_READ}</a></li><!-- ENDIF -->
</li>
<!-- IF S_DISPLAY_SEARCH -->
<li class="top"><a href="{U_SEARCH}" id="forumsearch" class="top_link"><span class="down">{L_SEARCH}</span><!--[if gte IE 7]><!--></a><!--<![endif]-->
<li><b>Common Searches</b></li>
<li><a href="{U_SEARCH_UNANSWERED}">{L_SEARCH_UNANSWERED}</a></li>
<li><a href="{U_SEARCH_ACTIVE_TOPICS}">{L_SEARCH_ACTIVE_TOPICS}</a></li>
<li><a href="{U_SEARCH_NEW}">{L_SEARCH_NEW}</a></li>
<li><a href="{U_SEARCH_SELF}">{L_SEARCH_SELF}</a></li>
<li><b>Custom Searches</b></li>
<li><a href="{U_SEARCH}">Advanced Search</a></li>
</li>
<li class="top"><a href="#" id="phpbbresources" class="top_link"><span class="down">Links</span><!--[if gte IE 7]><!--></a><!--<![endif]-->
<li><b>Header 1</b></li>
<li><a href="#">Link 1</a></li>
<li><a href="#">Link 2</a></li>
<li><a href="#">Link 3</a></li>
<li><a href="#">Link 4</a></li>
<li><b>Header 2</b></li>
<li><a href="#">Link 5</a></li>
<li><a href="#">Link 6</a></li>
<li><a href="#">Link 7</a></li>
<!-- IF U_ACP -->
<li><b>Admin Links</b></li>
<li><a href="#">Link 8</a></li>
<li><a href="#">Link 9</a></li>
<li><a href="#">Link 10</a></li>
</li>
<li class="top"><a href="{U_SEARCH_NEW}" class="top_link"><span>{L_SEARCH_NEW}</span></a></li>
<div id="page-header">
<div class="headerbar">
<div id="site-description">
<h1>{SITENAME}</h1>
<p>{SITE_DESCRIPTION}</p>
<div id="search-box">
<fieldset>
</fieldset>
</form>
<li class="icon-home"><!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a> » <!-- ENDIF --><a href="{U_INDEX}" accesskey="h">{L_INDEX}</a> <!-- BEGIN navlinks --> <strong>‹</strong> <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></li>
<div id="page-body">
ok provo a vedere dal tuo in caso non riesco ti allego il mio template ..
- Valued Contributor
- phpBB.de User: MB34
in English (translated by Babelfish)
ok I try to see from yours in case I do not succeed I enclose you my template ones.
MrBaseball34
Hook 'em Horns
![Image](http://www.delphicommunity.com/board/images/texas2.gif)
2005 College Football National Champions
2005 College Baseball National Champions
Hook 'em Horns
Sorry, i dont understand what you mean... you can compare your File with mine to find the needed lines, oder you can just use the whole file from me...
<head>
<meta name="verify-v1" content="" />
<meta name="title" content="">
<meta name="description" content="">
<meta name="keywords" content=",">
<meta name="author" content="Alberto">
<meta name="copyright" content="Alberto">
<meta http-equiv="Reply-to" content="">
<meta http-equiv="content-language" content="IT">
<meta http-equiv="Content-Type" content="text/html; iso-8859-1">
<meta name="ROBOTS" content="INDEX,FOLLOW">
<meta name="creation_Date" content="03/1/2009">
<meta name="revisit-after" content="7 days">
{META}
// <![CDATA[
if ({S_NEW_PM})
* Find a member
return false;
</script>
<!--[if lt IE 7.]>
<![endif]-->
<link rel="stylesheet" href="{T_THEME_PATH}/alertinfo.css" type="text/css">
<DIV id="info">
<DIV id="infobar">
<a href="ucp.php?mode=register"><B>Non sei registrato...Clicca QUI per Registrarti e utilizzare tutte le funzionalita' del forum e accedere alle sezioni!</A></B></DIV></DIV><BR />
<!-- IF S_IN_ARCADE -->
<link href="{T_THEME_PATH}/arcade.css" rel="stylesheet" type="text/css" media="screen, projection" />
</head>
var gaJsHost = (("https:" == document.location.protocol) ? "https://ssl." : "http://www.");
document.write(unescape("%3Cscript src='" + gaJsHost + "google-analytics.com/ga.js' /javascript'%3E%3C/script%3E"));
</script>
try {
var pageTracker = _gat._getTracker("UA-8315841-2");
pageTracker._trackPageview();
} catch(err) {}</script>
<div id="wrap">
<!-- INCLUDE navigation.html -->
<a href="{U_INDEX}" title="{L_INDEX}" id="logo">{SITE_LOGO_IMG}</a><br />
<h1>{SITENAME}</h1>
<fieldset>
</fieldset>
</form>
//<![CDATA[
document.write('<s'+'cript type="text/javascript" src="(banner Mio sito)468X60/r='+new Date().getTime()+'"><\/s'+'cript>');
</script>
//<![CDATA[
document.write('<s'+'cript type="text/javascript" src="(banner Mio sito)125X125/r='+new Date().getTime()+'"><\/s'+'cript>');
</script>
//<![CDATA[
var l='it';
document.write('<s'+'cript type="text/javascript" src="(banner mio sito)cat.av?'+new Date().getTime()+'"><\/s'+'cript>');
</script>
//<![CDATA[
document.write('<s'+'cript type="text/javascript" src="(banner mio sito)js.ad/size=728X90/r='+new Date().getTime()+'"><\/s'+'cript>');
</script>
<li class="icon-ucp"><a href="{U_ARCADE}" title="{L_ARCADE_EXPLAIN}">SALA GIOCHI</a></li>
<li class="icon-ucp"><a href="http://downdb.altervista.org/viewtopic.php?f=4&t=40" title="guida">GUIDE</a></li>
<li class="icon-ucp"><a href="tolbar mio sito/" title="toolbar">La toolbar di DownDB</a></li>
<li class="icon-logout"><a href="{U_LOGIN_LOGOUT}" title="{L_LOGIN_LOGOUT}" accesskey="l"></a></li>
<!-- IF (S_ARCADE_DISABLED and S_USER_LOGGED_IN and U_ACP) or (S_ARCADE_REPORTS and S_ARCADE_REPORTS_OPEN) -->
<!-- IF S_ARCADE_DISABLED and S_USER_LOGGED_IN and U_ACP -->{L_ARCADE_DISABLED}<!-- ENDIF -->
<!-- IF (S_ARCADE_DISABLED and S_USER_LOGGED_IN and U_ACP) and (S_ARCADE_REPORTS and S_ARCADE_REPORTS_OPEN) --> <!-- ENDIF -->
<!-- IF S_ARCADE_REPORTS and S_ARCADE_REPORTS_OPEN --><a href="{U_ARCADE_REPORTS_OPEN}">{ARCADE_REPORTS_OPEN}</a><!-- ENDIF -->
Ah, your header is modded... ok... Then you need to search my code for the string, and so you can find the place where you have to add the lines.
