http://www.awesomestyles.com/phpbb3-sty ... s-darkblue
Thanks
Glass Dark blue
- Valued Contributor
- phpBB.de User: MB34
Re: Glass Dark blue
Glass styles are decended from prosilver, did you try the basic install, yert?
MrBaseball34
Hook 'em Horns
2005 College Football National Champions
2005 College Baseball National Champions
Hook 'em Horns
Re: Glass Dark blue
The block images do not show up.
http://theoutcasts.net/theme.jpg
This theme is just like our old nuke plat site and would be ideal to use but I am new to phpbb3.
Is there a guide on how to convert themes to board3?
Thanks
Thanks
Re: Glass Dark blue
This Style is freaky to adapt since it uses all files from prosilver. If you want to change anything, you have to do it in prosilver. But this would destroy the prosilver Style
EDIT: Maybe theres a way using a template.cfg with "inherit_from = prosilver"
I'm playing around with it to get a solution...
EDIT2: I got it working with this Method... but there are a lot of changes needed to havea nice look too...
that what i get for now: http://area51.mikevil.de/portal.php?style=52 (watch it in IE too... )
Re: Glass Dark blue
I do not mind moding prosilver at all. I will never use it. That looks good so far. We will use the blue theme forever all of our banners match. Thank you for your time. I will keep a link on our page to here for life.
Re: Glass Dark blue
mike, please can you describe what you did to display properly the glass style? I still have not managed to fix it...
here's the link:
http://bravotuning.it/forum/__portal.php
thanks for the support!
here's the link:
Re: Glass Dark blue
The style is based on phpBB: 3.0.4 and makes errors in IE.DaveDevil wrote:mike, please can you describe what you did to display properly the glass style? I still have not managed to fix it...
here's the link:
Therefore not suitable for the portal.
Re: Glass Dark blue
mmh i use firefox, something changes? no way to "update" it to the new version? like someone who did the modifications?
