World of Warcraft Progress Block
Thunderspud
- phpBB.de User: Thunderspud
- phpBB.com User: Thunderspud
Is anyone working on a raid progression for Board3? I see the other mods that I used have been ported over. I would also like to add that I am very thankful for those that take the time and effort to code. I know it’s not easy and can invite all kinds if headaches.
vicster
Re: World of Warcraft Progress Block
A little Bump to the OP, showing some interest in this to.
Ice
The original author has shown interest in porting the block over, as I understand he is currently working on it.
Teksonic
- Portal Enthusiast
- phpBB.com User: Teksonic
I have started the process of porting my phpbb3portal block over to board3. While doing this I've decided to do some revamping to it and clean up the ACP module a lot. It was starting to get cluttered with so many raids. Also I will be creating a separate version that will track two 25 man team progress.
Here are some example pics of the old raid progress to give you an idea. (again this was built for phpbb3portal)
this is the old ACP the new one may look similar or could be completely different when i'm done re writing it.
Hopefully I will be able to add the new raid instance thats currently on the PTR into this rewrite also.
Guild - Iron Circle
Server - Llane
Guild - Iron Circle
Server - Llane
vicster
Looks Fantastic!, im looking very much forward to it !
solaxx
- phpBB.com User: solaxx
Neeeed
I've started to adapt your original version (for phpbb3 portal) for my board, but I think I will wait this new version.
Thanks in advance.
Thanks in advance.
Guilde Reflets Noirs : http://www.refletsnoirs.net
maniacal
I'm also quite interested in it. I'm currently using the bbdkp one (adapted for board3), but am loving what you have there. If you need a live tester for it, let me know
Thanks for all the work you're putting in!
-Maniacal
http://www.perfecteulogy.net
-Maniacal
ketra90
looks great, whats status on this 1?.. im very very intrested.
Teksonic
- Portal Enthusiast
Update
The re-creation of the block is almost finished. (woot) Overall the new mod will be much easier to use, and has more room for me to advance it in the future. On top of that the new version will have included at release the new Trial of the Crusader raid. all modes 10/25 normal and heroic, plus the Onyxia's Lair will be included for use as soon as the new patch hit's.
I still need to write an installer for this as most of it will install automatically.
Guild - Iron Circle
Server - Llane
Guild - Iron Circle
Server - Llane
Dr Nick^
- Valued Contributor
gj tek.
dont forget the new way of putting language files etc
in dev part.
works better then portal3 imo.
in dev part.
Teksonic
- Portal Enthusiast
oh yes, this release is totally localized. If anyone wants to convert it into other language's I will have no problem with it and bundle that with the download.
Guild - Iron Circle
Server - Llane
Guild - Iron Circle
Server - Llane
solaxx
I can help if you need translation in French, I've already done this with other blocks (recruitment, old progress block).
cromatics
- Portal Enthusiast
Teksonic
- Portal Enthusiast
The version i'm working on currently is live on my test site. If you would like to go look feel free. There's no access to the ACP at this point as i'm still coding.
test.iron-circle.com
let me know if you have any comments.
Guild - Iron Circle
Server - Llane
Guild - Iron Circle
Server - Llane
maniacal
That looks fantastic Tek. I'm looking quite forward to this. It will look much nicer than the simple bbdkp modified one I am currently using. Let me know if you need a live tester!
