Fatal error: Call to undefined function display_forums() in /home/photo79/public_html/theamericanwill/portal.php on line 91
Not sure where I need to look
calling form http://www.theamericanwill.com
Fatal Error after install
Moderator: Dyo
TheAmericanWill
TheAmericanWill
MrBaseball34
- Valued Contributor
- phpBB.de User: MB34
Re: Fatal Error after install
the display_forums function is in includes/functions_display.php Make sure that the mods that added that as a requires actually happened.
I find that search.php is the file you need to check.
MrBaseball34
Hook 'em Horns
2005 College Football National Champions
2005 College Baseball National Champions
Hook 'em Horns
TheAmericanWill
thanks, went to a different portal
MrBaseball34
Really? Which one?
MrBaseball34
Hook 'em Horns
Hook 'em Horns
TheAmericanWill
Portal XL5 Premod
Your is great, Just thought this added what I needed
