Please...fisubice2
- phpBB.de User: MB34
Please...fisubice2
How hard would it be to do the fisubice2 style?
MrBaseball34
Hook 'em Horns
![Image](http://www.delphicommunity.com/board/images/texas2.gif)
2005 College Football National Champions
2005 College Baseball National Champions
Hook 'em Horns
Re: Please...fisubice2
This is what it looks like, if you follow the install instructions for subsilver2: http://area51.mikevil.de/portal.php?style=47
Note: You dont find the breadcrumbs.html for this style, cause it uses the one from subsilver2. Therfore you have to add the line in the breadcrumbs.html within the subsilver2 folder![Zwinkern ;)](./images/smilies/icon_e_wink.gif)
Cool. Now, after running the subsilver2.xml install, it says to view the install.xml for more.
What does that mean exactly?
Also, will DYOs MOD PortalView work with this? I couldn't get it to work with AeroBlue and
really like fisubice2 better...
MrBaseball34
Hook 'em Horns
Hook 'em Horns
If you install the Portal, you have to view the install.xml too... But if you only install your style, you can ignore that ![Zwinkern ;)](./images/smilies/icon_e_wink.gif)
Portalview is for 1.0.2 but there are any discussions about how to get it to work on 1.0.3
I know that but if I'm installing Board3 after the style is installed, will I have to make changes to anythingMike wrote:If you install the Portal, you have to view the install.xml too... <SNIP>
besides running subsilver2.xml?
I just don't get why AutoMod doesn't allow you to select which style to install to.
MrBaseball34
Hook 'em Horns
Hook 'em Horns
OK, all installed, I did manually because AutoMOD didn't work correctly.
See my subsilver2.xml fix posted in the English Forum.
MrBaseball34
Hook 'em Horns
Hook 'em Horns
Thanx...
But i think its not too hard to do it manualy, is'nt it?![Zwinkern ;)](./images/smilies/icon_e_wink.gif)
And sorry for no answering you question, i have'nt seen it.![Zwinkern ;)](./images/smilies/icon_e_wink.gif)
No.MrBaseball34 wrote:I know that but if I'm installing Board3 after the style is installed, will I have to make changes to anything
Yeah but I had to make a change to the subsilver2xml file as stated in my post in the English Help forum.
MrBaseball34
Hook 'em Horns
Hook 'em Horns
