warcraft recruitment block (port from phpbb3portal)
talonos
Portal Specialist
phpBB.com User: talonos
Post by talonos »
ok i've made a port over from phpbb3portal to board3 this is the recruitment block that sheepy made (original link here)
read the install_board3.txt for board3 install instructions
DOWNLOAD:
download/file.php?id=214
any errors with installing this block reply here OR here)
Thanks to Ice for noticing that i missed a board3 code change that i missed, ALSO Ice just notice u put a block image in there and fixed up the block file a little too :) hopefully anymore ports i do will have these things sorted before hand **touch wood** lol
SUPPORT ON THIS BLOCK HAS BEEN STOPPED please refer to link below for NEW recruitment block
http://board3.de/viewtopic.php?f=9&t=4150
UPDATED 28th June 2009
Re: warcraft recruitment block (port from phpbb3portal)
Thanks for sharing, talonos! :)
Thunderspud
phpBB.de User: Thunderspud
phpBB.com User: Thunderspud
Post by Thunderspud »
I installed the mod for my board III portal following the directions in install_board3.txt but I am not able to see the mod even after a cache refresh. Now, I can see it in the ACP, and I have even set some of the options. any ideas?
www.thedemiseofexodar.com
talonos
Portal Specialist
Post by talonos »
Thunderspud wrote:I installed the mod for my board III portal following the directions in install_board3.txt but I am not able to see the mod even after a cache refresh. Now, I can see it in the ACP, and I have even set some of the options. any ideas?
http://www.thedemiseofexodar.com
is ur dns working because @ the moment i follow ur link and no pages are displayed at all
maniacal
Post by maniacal »
Thanks for converting this; I had tried my hand at it but couldn't get it to work.
Unfortunately I am in the same situation now. I'm using Board3 alongside BBdkp, choosing to use the board3 portal instead of the bbdkp default. I am using the WoWKing Style (based on Prosilver). I got the ACP module to show up, turned it on, set up a couple messages, and nothing appeared. I took out the <!-- IF S_DISPLAY_PORTAL_RECRUITMENT --> and the ENDIF from the portal_body page, and the block appears, but the data itself does not show up. Any thoughts?
http://www.perfecteulogy.net/forums/
Ice
Post by Ice »
The link to the zip is down right now so I can't look, when it comes back up I'll check.
(If someone reads this and checks the link and it's not down, give me a prod to remind me to come back and check.)
Ice
Post by Ice »
Disregard above post, that site has some anit-hotlinking script in place that makes the link not work. I've uploaded it to this server so it will now work.
Ice
Post by Ice »
Wee spam.
From a quick read of the files there are a lot of mentions of '$config', which Board3Portal doesn't use. We use '$portal_config'.
Go through the install file, for every time you pasted in $config change it to $portal_config.
You're gonna need to edit /portal/block/recruitment.php and change $config for $portal_config too.
maniacal
Post by maniacal »
Thanks! Only other issue is not getting the associated images to appear next to the class (its putting the class name next to the correct, colored class name). Directory seems to be in the right place, with correct folder permissions. Am I missing something else?
Ice
Post by Ice »
I've redone the entire package, those who have already installed will have to install it all again.
recruitment_block.zip
Recruitment Block, Board3 Style
(21.68 KiB) Downloaded 3452 times
maniacal
Post by maniacal »
Ice, Thanks a ton for the fix. Talonos, thanks to you as well for getting this off the ground. It's precisely what I needed for that page.
Ice
Post by Ice »
Glad it works. :)
talonos
Portal Specialist
Post by talonos »
Ice wrote:I've redone the entire package, those who have already installed will have to install it all again.
thanks Ice i knew there was something i had forgot but i just couldn't thnk what it was i'll update my first to your fixed version, thanks for sorting it now many a guild can get it going and hopefully in future i remember that recode issue
Thunderspud
my bad, and i have been off for 3 days. my site is: www.demiseofexodar.com. I follwed the steps, no errors and i have access to it in the ACP, but it doesnt seem to display.
:oops:
Ice
Post by Ice »
No problem talanos, everyone has to start somewhere and it was pretty good for a first try. :)
Thunderspud, is that the original version or the new version?
