Error urjent help required
Khamosh-Saya
phpBB.de User: Khamosh-Saya
phpBB.com User: Khamosh-Saya
Post by Khamosh-Saya »
Your Portal Version: 1.0.3
Boardlink: http://www.friendzsociety.com
Forum Update and Portal update
Nothing
i m facing this error from the last
Warning: main(./common.php) [function.main]: failed to open stream: No such file or directory in /home/friendz/public_html/portal.php on line 20
Warning: main() [function.include]: Failed opening './common.php' for inclusion (include_path='.:/usr/php4/lib/php:/usr/local/php4/lib/php') in /home/friendz/public_html/portal.php on line 20
Fatal error: Call to a member function on a non-object in /home/friendz/public_html/portal/includes/lang_adm_additional_blocks.php on line 19
Before m post in phpbb.com that i have uninstall and install the portal coz of fatel error..
after that i cant see ACP settings.
but now this problem start i cant access mine board[/i]
Re: Error urjent help required
Problem solved?
Khamosh-Saya
yes kevin problem solved.
but i m facing one more problem
i have update mine forum 3.0.0 to 3.0.5 after that i have update portal..
some errors start in mine forum due to welcom panel i thought that errors start due to portal and m uninstall and then isntall again portal
after portal is working fine but i cant see Configration in ACP...
what to do?
Khamosh-Saya
Bump topic
what to do ACP Setting not appear
Ice
Post by Ice »
You can add the portal to the ACP manually by going to ACP -> System -> Module management -> .MODS -> Create new module 'Portal' -> then Add Module all the modules under the Portal heading on the dropdown.
Khamosh-Saya
Ice i have done this ... but after that when i go and click on .Mods
i cant see Portal Configration
Ice
Post by Ice »
make sure you've clicked "enabled" on the module page.
Khamosh-Saya
Ice wrote:make sure you've clicked "enabled" on the module page.
i m 101% sure i have enable the Modules
Ice
Post by Ice »
strange, would you be willing to allow me to look at the ACP of your board?
Ice
Post by Ice »
You are missing the portal permissions section, which means you may have missed the edits to adm/index.php
Khamosh-Saya
Ice wrote:You are missing the portal permissions section, which means you may have missed the edits to adm/index.php
okz let me check
Khamosh-Saya
i have check Ice
Everthing is ok in mine adm/index.php
Khamosh-Saya
Ice waiting for Responce
Ice
Post by Ice »
I seriously don't know what is wrong, I've exhausted all I can think of, sorry.
Khamosh-Saya
Okz
What is the last solutions?
