Pagination on the Compact Announcements Block
Maverick
Post by Maverick »
Your Portal Version: 1.0.3
Boardlink: http://www.pitlanefanatic.com/portal.php
Modified the announcements block to operate as a second new block
I believe this may simply be a case of pointing me in the right direction as I think the answer is in the functions.php file - hopefully somebody who knows their way around it better than me can help.
I've converted my announcements_compact.html block to operate as a second news block so that I can differentiate between two sections of the forum. All is fine except for one small problem - the pagination at the bottom of the block. Whereas I have got the block to read and display all types of article the pagination still only counts announcements.
Can this be changed to count all article types from the specified forums and if so, how?
Thanks in advance
http://www.vivaf1.com - motorsport portal
