Hi, its possible to redirect user after he write massage to portal not to topic?
Redirect to portal
Re: Redirect to portal
Yes, should be. Not tested:
Open posting.php
seach:
replace with:
Note: this only changes the redirection. If you want the message to be changed, you have to modify $user->lang['VIEW_MESSAGE']
Open posting.php
seach:
$message = $user->lang[$message] . '<br /><br />' . sprintf($user->lang['VIEW_MESSAGE'], '<a href="' . $redirect_url . '">', '</a>'); Code: Select all
$message = $user->lang[$message] . '<br /><br />' . sprintf($user->lang['VIEW_MESSAGE'], '<a href="' . append_sid("{$phpbb_root_path}portal.$phpEx") . '">', '</a> '); ~~~ They say the definition of madness is doing the same thing and expecting a different result ~~~
