change "board index" to "Forum"
d0s3
phpBB.com User: d0s3
Post by d0s3 »
Your Portal Version: 1.0.2
Boardlink: http://crizzo-designs
Not a problem just want help changing one thing.
searching forums looking for answer
How do I change the menu block from from saying "Board Index" to "Forum"?
I searched the help here but found only how to add a link, I dont wanna do that I just wanna change what I have, I tried changing the L_index/u_index and it didnt work?
Thanks
Christopher
d0s3
Re: change "board index" to "Forum"
Post by d0s3 »
my site is:
http://crizzo-designs.com
sorry about that it wouldnt let me edit my mistake! :?
Where did you change L_INDEX ?
You need to change it in language/*yourlanguage*/common.php
d0s3
Post by d0s3 »
I didnt see "board index" only found "index => Index page", I changed it and refreshed and purged cache it still is showing as board index? Is there anything else I would need to do or edit to get it to show?
Thanks,
Christopher
You should maybe use the search function:
viewtopic.php?f=10&t=2127&hilit=change+board+index
d0s3
Post by d0s3 »
Thanks!
I did this but it didnt change for me, even after refreshing and purging cache'. Oh well no biggie!
Thanks
Christohper
