Boardlink: http://www.clarify.net/
nothing
looked at the code
Hi there,
Please have a look at the code in recent.php (root/portal/block).
// Recent announcements
$sql = 'SELECT topic_title, forum_id, topic_id
FROM ' . TOPICS_TABLE . '
WHERE topic_status <> ' . FORUM_LINK . '
AND topic_approved = 1
AND ( topic_type = ' . POST_ANNOUNCE . ' OR topic_type = ' . POST_GLOBAL . ' )
AND topic_moved_id = 0
' . $sql_where . '
ORDER BY topic_time DESC';
$result = $db->sql_query_limit($sql, $portal_config['portal_max_topics']);
while( ($row = $db->sql_fetchrow($result)) && ($row['topic_title']) )
// auto auth
if ( ($auth->acl_get('f_read', $row['forum_id'])) || ($row['forum_id'] == '0') )
$template->assign_block_vars('latest_announcements', array(
'TITLE' => character_limit($row['topic_title'], $portal_config['portal_recent_title_limit']),
'FULL_TITLE' => censor_text($row['topic_title']),
'U_VIEW_TOPIC' => append_sid("{$phpbb_root_path}viewtopic.$phpEx", 'f=' . ( ($row['forum_id'] == 0) ? $g_forum_id : $row['forum_id'] ) . '&t=' . $row['topic_id'])
}Can you tell me how to patch this code so the number of recent topics is always the one in $portal_config['portal_max_topics'], regardless of forum privileges? Thanks![/i]
