upgrade 1.02 -> 1.03 failure in install script
DutchToxophilite
phpBB.com User: DutchToxophilite
Post by DutchToxophilite »
Your Portal Version: 1.0.2
Boardlink: http://www.handboogforum.nl
Problem is with install script (xml file) of boardIIIportal1.0.3 (from 1.0.2)
I have created a screenshot.
Hi.
The XML file to upgrade board 1.0.2 to 1.0.3 has a small failure.
Please see attached screenshot.
http://www.handboogforum.nl/picture_lib ... hot544.jpg
thanx.
grtz,
Twan
The joy's of Archery can be found anywhere. Far places only offer exotic ways to suffer.
Re: upgrade 1.02 -> 1.03 failure in install script
Thanks for the report, but this is correct and meant to be this way.
It means: find this code and delete it (--> replace with "nothing").
Due to a missing "delete" tag in the ModX XMLs, we were forced to do it this way.
DutchToxophilite
Ah....
I understand.
And now you mention it like this, I can not think of another way to do this.......
Thanx!!!!
grtz,
Twan
You're welcome. And i know - it's a bit confusing. Maybe we should ask the ModX team to implement a "delete" tag. ;)
z.B.
<find-del><![CDATA[Blablabla]]></find-del>
Was dann vllt. sowas wird wie:
Find and delete
Blablabla
Habs jedenfalls mal zur nickvergessen es geschrieben, vllt. wird da in der nächste XML-Datei ja irgendwas eingepflegt mal schauen. :)
