Your Portal Version: 1.02.2
MySQL Version: MySQL client version: 5.1.30
edited and placed files
using the FAQ,s and search option on 4 different forums
i downloaded the portal page files and in the intsall.xml file it contains no info on what todo to the mysql database, as in creating a new table etc
do u have the set up info i need todo this please
errors on page
SQL ERROR [ mysqli ]
Table 'php-tester.phpbb_portal_config' doesn't exist [1146]
note this is on a local host testing forum ?
thanks in advance for any advice
info needed on database creation
- phpBB.de User: thomas.d
- phpBB.com User: thomas.d
Re: info needed on database creation
You will have to run the installer. This will setup all necessary tables in your db.
Thomas
Deutsche Sprachdateien für
ACP Add User MOD 1.0.0 |
Thomas
where will i find this in the files that i downloaded and plavce the installer?
Try reading the install.xml carefully. The copy and DIY instructions.
For future questions please search the forum and read our knowledge base, before posting them: knowledge/Browse to install/ and run the installer
Refresh your Styles:
i see the above line ,but unfortunatly it means nothing too me id prefer if it said
root/install/installer
but theres not such file
apart from root/install/install_install.php
so if i need too put this install_install.php file some where i dont know where it goes
sorry for my ignorence but i am new too this ,i have no problem with the edits and placing of the other files etc
i queryed my database
of a post on here which did create the 'php-tester.phpbb_portal_config' but stll found the error coming up
it's very easy, just place the "install" folder in your root, then with your browser, point to http://www.yoursite.com/install and follow the onscreen directions
Simply unzip the portal package, keeping the contained directory structure.
Browse into the the root directory of the package and upload all (including the subdirectorys / files) to the root directory of your forum (also keeping the structure). The root directory of your forum is where you find e.g. the viewtopic.php, config.php of phpBB3.
Then do it as FLATTOP wrote and you'll find the portal installer.
It should be simple as that.
hi i have tryed this upto four times with no avail,the installer wll not create or update any info in mysql database and still have the same error
ive given up and wondering if u could point me in a direction where i could get some one too install this mod on my live forum please
