Update/Install ACP Issue[Solved]
paragon
Post by paragon »
Your Portal Version: 1.0.3
I have installed phpbb3 3.0.4, installed several modifications (listed as follows: phpbb3 gallery, filebase, and a calendar system. Only the gallery and filebase use the ACP in .MODS) along with an older version of the Board3 portal. All was well until upgrading to the newest version.
I attempted to uninstall and reinstall resulting, obviously, in the loss of my preferences of board3 and no fix to the problem.
After a upgrade install I seen that there was no Control panel for board3 in the .MODS ACP, I then continued to do what I described above as a possible solution to discover the reinstall did not change anything (except for losing my board3 configuration, which was expected).
khikho
phpBB.com User: khikho
Re: Update/Install ACP Issue
Post by khikho »
I have the Same Problem :?:
~HG~
Post by ~HG~ »
My upgrade went relatively smoothly.
Did you run the /install folder with the instructions on how to update?
Did you delete the files (if any) required to be deleted?
Once I had v1.0.3 installed I then over wrote the new blocks and template files with my own which I had modified to suit my board and now all is good once again.
If you run the /install folder, you can also use it to uninstall board3 so I suggest you take that line and then reinstall following the .xml instructions for a new installation.
~HG~ wrote:Once I had v1.0.3 installed I then over wrote the new blocks and template files with my own which I had modified to suit my board and now all is good once again.
Thats a really bad idea. The most of the blocks have several changes /bugfixes, and if you use your old Blocks, you dont have the latest Version of B3P.
paragon
Post by paragon »
I did use the correct .xml file instructions(for an update from a previous version) along with deleted the appropriately depreciated files. Is there no fix/solution? I have uninstalled and reinstalled it several times. I am about to revert to an old version or uninstall it totally/find another solution.
paragon
Post by paragon »
This was solved by deinstalling the said mods above, installing the portal and then re-installing said mods.
