Is there a way to upgrade from the old version ?, i dident notice one, just a fresh install ...
Gordon
Upgrade
Re: Upgrade
As in 0.1.0? When you run the install script there should be an option to update in the middle of the screen.
Re: Upgrade
So can you tell me how to upgrade ?.
Do i upload all the files in the new version and just run the install script ? ...
Re: Upgrade
Depending on wich version you have installed, you should take a look at \contrib\upgrade<youroldportalversion>.xml's ![Zwinkern ;)](./images/smilies/icon_e_wink.gif)
Re: Upgrade
Aha !, so thats where it is
Sorry i dident look.
Now to decide which version i have
![Lächeln :)](./images/smilies/icon_e_smile.gif)
Re: Upgrade
The only place i can see what version i have is in the Portal.php.
And it says :- * @version $Id: portal.php 101 2008-01-15 21:51:42Z kevin74 $ ...
Re: Upgrade
This is version 0.1.0 - we'll add a version info to the ACP in future versions.
Re: Upgrade
Thank you, that would be helpful ...
