Your Portal Version: 1.0.3
Boardlink: http://www.neweditionfanclub.com/board
Nothing
Nothing
Today I updated from PHPBB 3.0.2 to 3.0.4 and then later this afternoon I installed the portal. After I installed the portal my ACP now says that I am not up to date and I am back at 3.0.2.
Board Reverted back to 3.0.2???
- phpBB.com User: candysmall
Re: Board Reverted back to 3.0.2???
I'd say: no portal issue, as we do not touch anything in the phpbb_config table at any time.
Maybe you haven't finished phpBB update (went to the end) - that would explain why you still have 3.0.2 as version displayed.
Moved to "general phpBB3 support".
The ACP only changed back after I installed the portal. Can it have anything to do with the database?
Dunno. I guess that it has something to do with a not completely finished phpBB update. There is a (temporary) flag in the config table during the update, which will only be removed after a successful update. This might be your problem.
But i can definitely say that this has nothing to do with the portal update or installation. As mentioned before: we do not touch at any time the phpBB version number (why should we?).
