Boardlink: http://rufclan.com
nothing
not really a problem
I use acidtech red and acidtech lime styles and when I originally installed my forum I did not do the edits that included in
as my overall_header.html file is pretty custom (from the style). I was wondering what these did and how important it would be to have them? here is my current overall_header.html file
<head>
<!-- INCLUDE ca_config.html -->
<meta name="copyright" content="2002-2006 phpBB Group" />
{META}
<title>{SITENAME} - <!-- IF S_IN_MCP -->{L_MCP} - <!-- ELSEIF S_IN_UCP -->{L_UCP} - <!-- ENDIF -->{PAGE_TITLE}</title>
<!-- IF T_STYLESHEET_LINK -->
<style type="text/css">
{T_THEME_DATA}
</style>
<!--[if IE 7]>
<link rel="stylesheet" type="text/css" href="{T_THEME_PATH}/ie7.css" />
<![endif]-->
// <![CDATA[
<!-- IF S_USER_PM_POPUP -->
if ({S_NEW_PM})
if (!name)
name = '_popup';
return false;
function jumpto()
var perpage = '{PER_PAGE}';
* Find a member
function find_username(url)
return false;
* Mark/unmark checklist
if (!parent)
if (!parent)
return;
rb[r].checked = state;
<!-- IF ._file -->
function play_qt_file(obj)
if (rectangle)
var width = 200;
var height = 0;
obj.width = width;
obj.height = height + 16;
obj.Play();
if(navigator.userAgent && navigator.userAgent.indexOf('Mac OS X') > 0)
document.write('<link rel="stylesheet" href="{T_THEME_PATH}/mac.css" type="text/css" />');
</script>
<script type="text/javascript" >
if (window.addEventListener) {
window.addEventListener("load",initLytebox,false);
} else if (window.attachEvent) {
window.attachEvent("onload",initLytebox);
} else {
window.onload = function() {initLytebox();}
function initLytebox() {
var imgMaxWidth = 1280;
var imgWarning = '';
myLytebox = new LyteBox(imgMaxWidth, imgWarning);
</script>
<script type="text/javascript" src="{T_TEMPLATE_PATH}/gallery_lytebox.js"></script>
} else {
</script>
<link rel="icon"
type="image/png"
href="http://rufclan.com/favicon.ico">
<!-- IF S_IN_ARCADE -->
<link href="{T_THEME_PATH}/arcade.css" rel="stylesheet" type="text/css" media="screen, projection" />
</head>
<a name="top"></a>
<table border="0" cellspacing="0" cellpadding="0" width="{$CA_WIDTH}" id="maintable" align="center">
<td id="logorow" align="center"><div id="logo-left"><div id="logo-right">
<a href="http://www.rufclan.com">{SITE_LOGO_IMG}</a>
</div></div></td>
<td class="navrow">
<a href="http://www.rufclan.com">Home</a> •
<!-- IF not S_IS_BOT -->
<!-- IF S_USER_LOGGED_IN --><a href="{U_PROFILE}">{L_PROFILE}</a> • <!-- ENDIF -->
<!-- IF S_DISPLAY_PM --><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}</a> • <!-- ENDIF -->
<!-- ELSEIF S_REGISTER_ENABLED --><a href="{U_REGISTER}">{L_REGISTER}</a> • <!-- ENDIF -->
<!-- IF U_RESTORE_PERMISSIONS --><a href="{U_RESTORE_PERMISSIONS}">{L_RESTORE_PERMISSIONS}</a> • <!-- ENDIF -->
<a href="{U_GALLERY_MOD}" title="{L_GALLERY_EXPLAIN}">{L_GALLERY}</a> •
<a href="{U_ARCADE}"> {L_ARCADE}</a> •
<a href="{U_FAQ}">{L_FAQ}</a>
<!-- IF S_DISPLAY_SEARCH --> • <a href="{U_SEARCH}">{L_SEARCH}</a><!-- ENDIF -->
<!-- IF S_DISPLAY_MEMBERLIST --> • <a href="{U_MEMBERLIST}">Site Users</a><!-- ENDIF -->
• <a href="http://www.rufclan.com/medals.php">Medals</a>
<!-- IF not S_IS_BOT --> • <a href="{U_LOGIN_LOGOUT}">{L_LOGIN_LOGOUT}</a><!-- ENDIF -->
<td id="contentrow">
<!-- IF not S_IS_BOT && not $CA_SKIP_PM_NOTIFY && S_USER_LOGGED_IN && S_DISPLAY_PM -->
<!-- IF S_USER_NEW_PRIVMSG -->
<div class="pm-notify-new"><div class="pm-notify-header">{L_PRIVATE_MESSAGES}</div><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}<!-- IF PRIVATE_MESSAGE_INFO_UNREAD -->, {PRIVATE_MESSAGE_INFO_UNREAD}<!-- ENDIF --></a></div>
<!-- ELSEIF S_USER_UNREAD_PRIVMSG -->
<div class="pm-notify-unread"><div class="pm-notify-header">{L_PRIVATE_MESSAGES}</div><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}<!-- IF PRIVATE_MESSAGE_INFO_UNREAD -->, {PRIVATE_MESSAGE_INFO_UNREAD}<!-- ENDIF --></a></div>
<!-- IF S_IN_ARCADE and S_ARCADE_DISABLED and S_USER_LOGGED_IN --> <span style="color: red;">{L_ARCADE_DISABLED}</span><!-- ENDIF -->
<!-- IF S_IN_ARCADE and S_ARCADE_REPORTS and S_ARCADE_REPORTS_OPEN --> <span style="color: red;"><a href="{U_ARCADE_REPORTS_OPEN}">{ARCADE_REPORTS_OPEN}</a></span><!-- ENDIF -->
<p class="searchbar">
</p>
<br style="clear: both;" />
