I want to add some new style to my phpbb3 and portal.
I download somme of them at this link : http://www.board3-styles.de/b3p_102/
I try to install reading the instructions but i have something i don't understand.
In the installation instruction it is say to
Edit this 2 files :
styles/darkness/template/breadcrumbs.html,
styles/darkness/template/overall_header.html
But this files does not exist in the style archive.
If i compare the new style folder with prosilver folder, there is a lot of missing files (html files).
Of course, i try to find the solution first, but i don't find it.
Please help me
Thx
Newb Question about style installation
Re: Newb Question about style installation
You have to download and install the Style too.
The B3P Download only contain Portal related files.
If i where you, i would wait some Days until the next Release of B3P.
So you dont have to do all again
Thanks for your help Mike
