Your Portal Version: 1.0.2
Boardlink: local
I installed many things and maked my style but I haven't a problem!
I tried it but it didn't function.
Hello!
I want to set the news modul on the right site in the sidebar, only with the topic title. Who can help me?
Thanks!
News in the sidebar!
Re: News in der Seitenleiste
No help?
Re: News in the sidebar!
Is ir really so difficuld?
Edit the template file to your needs and move the block to the site: Moving blocks / change orderRazer wrote:Is ir really so difficuld?
But you'll soon recognize that you get problems with the width. There is simply too much information in this block, to put in a 180px width. Not enough space...
You can remove most of the contend, but you will get in trouble with the length of the topic titles anyway. And if you shorten them to fit, it is too short to make sense anymore.
But when somebody can me say, how I can progarmm it so, that only the first XX Characters of the topic title are showed?Kevin wrote:Edit the template file to your needs and move the block to the site: Moving blocks / change orderRazer wrote:Is ir really so difficuld?
