Your Portal Version: 1.0.2
Boardlink: http://knxforum.se/portal.php
I am having problem with the center blocks that they are to wide.
Look at http://knxforum.se/portal.php
/mike
[SOLVED] Problem with width of middle part
Re: [SOLVED] Problem with width of middle part
It is solved
Did something wrong when i translated to swedish.
/Mike
/Mike
felsmanrio
- phpBB.de User: felsmanrio
- phpBB.com User: felsmanrio
I saw that you are using the prosilver style (or similar)!
I have the same problem with width of "middle part"! I´m using subsilver2. My phpbb is 3.0.4. I have MODs but nothing abaout style!
I Would like to know waht do you did to solve your problem? Please!
I need to use the subsilver2 style! Thanks!
RESUME:
I want to change de width of my middle column in board3 - Subsilver2 Style!
Here is my portal: http://estudoswebfree.nxserve.net/websi ... portal.php
I´m brazilian and the website is in portuguese! But it´s not important... I only need a help to change the width of middle column in subsilver2 style!Please!
Thks very muth!
Regards,
Felsmanrio!
RESUME:
Thks very muth!
Regards,
Felsmanrio!
felsmanrio
I solved my problem too!
Thanks!
Thanks!
